Friction Disc issue? - Snowblower Forum : Snow Blower Forums
post #1 of 50 Old 11-23-2015, 09:43 PM Thread Starter
So I have maybe 20 hrs on a new Platinum 30 I bought Jan 2015. Opened up the bottom pan tonight to get things ready for this yr and this is what I find.
I know some friction disc wear and rubber dust/fragments is normal but to me this is excessive for 20 hrs. Plus the surface of the disc is not worn equally across the surface.
Thoughts? Is this excessive (and should take back to dealer for warranty)?
Dpach is offline
post #2 of 50 Old 11-23-2015, 09:51 PM
Likes (Received): 82
Is it possible some oil or very little grease dropped on the disc wheel or even water as the wheel portion seems dirty with either I mentioned before.
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
post #3 of 50 Old 11-23-2015, 10:06 PM
Me i have a 2012 platinum 30 and did the same thing. I have this black rubber powder Every year when i made the maintenance. i think it's probably normal. Maybe the belt make some too.
4 winter and the disc is top shape.
po_the_drum is offline
post #4 of 50 Old 11-23-2015, 10:16 PM Thread Starter
Could be possible as the gears had quite a bit of grease on them. The dealer really greased it; perhaps too much.
I guess my main concern is whether I should load this up and see if warranty will replace the disc or will the disc settle in now that it is broke in?
Dpach is offline
post #5 of 50 Old 11-23-2015, 11:03 PM
Those disks are worth around $35.00 plus the trouble for install so it is up to you, did it feel like it was lurching when engaged in forward or rear?
My guess is that the warranty won't cover this since it is a wear item but ask your dealer what he thinks after all it is his fault. Good Luck
Normex is offline
post #6 of 50 Old 11-23-2015, 11:09 PM Thread Starter
Runs and drives just fine. There's no issues with the drive/movement. Since I have 2 more yrs warranty (and likely not covered as a wear item), will probably use it and check every month or so through the snow season (if we get any again this year).
Dpach is offline
post #7 of 50 Old 11-24-2015, 11:54 AM
Had the same issue on mine with no operational issues.
Cleaned the disc and general area but have yet to do it this year however i expect to find the same thing as you posted.
The disc had some thin rubber ring around it from manuf. of it and i assumed that it is that which has worn off?
Still no ops issues with one use this year......might give Ariens a call just to be sure?
I had to adjust the tension on the engagement and thought maybe it was too tight but it was definitely too loose before.
AverageJoe is offline
post #8 of 50 Old 11-24-2015, 01:03 PM Thread Starter
Yeah, I will take a rag with some gasoline and clean the drive plate and disc to remove any residual grease/oil since they really greased this thing when they put it together. I should have opened her up when I got it home and wiped off the excess grease but I thought a reputable Arien's dealer would have known not to over grease things. Oh well. Friction discs are not hard to replace on these machines and not too expensive. Will run it a second year and just check it a couple times through the winter. I will also check the engagement tension too.
Dpach is offline
post #9 of 50 Old 11-24-2015, 02:02 PM
Thanks (Received): 8
Likes (Received): 19
Looks normal. One of the reasons I went with a hydro machine was because the friction disc was always wearing quickly no matter how well I maintained it. Any resistance at all will cause it to slip, hence the debris. Even working a snowbank is high stress for a friction disc. The system works well for moderate residential use for the most part, but it is not robust by any means. I don't miss it, that's for sure.
Ariens Hydro Pro 28
Snowhawg is offline
post #10 of 50 Old 11-24-2015, 02:08 PM
Just to be sure check if it is a warranty item with your dealer and if not I would buy a spare one for when you might need it just before a storm.
Normex is offline
