Debris in fuel tank?? - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 12-09-2015, 02:30 PM Thread Starter
I recently bought a 24" Platinum SHO, I've had a few small issues right after taking delivery; auto turn issues as others have noted, heated hand grips not being secured with rivots and NOW after pulling it out of the shed to give it another look, I noticed a substantial amount of metal shavings in the fuel tank.
Below is another person with the same concern with the same model.
https://www.snowblowerforum.com/forum...s/27625?page=1
Is this common in the manufacturing process? Should I be concerned? Or just do my best to clean the fuel tank out?
Should I let the dealer know of the issue in case any damage has already occurred as they will inevitability take care of it if any serious damage does occur within the warranty period?
StefanC is offline
post #2 of 12 Old 12-09-2015, 02:37 PM
Likes (Received): 280
I think those have an inline filter don't they? Either way you shouldn't have junk in a brand new one..... seems like the dealer should be made aware. I seriously doubt it would hurt anything but I would drain it on the filtered side, then pull thte tank and dump it. Hopefully the dealer will offer to do it...... they should have checked it over in the first place. I can understand them missing it I suppose - but they should know from now on to look.
post #3 of 12 Old 12-09-2015, 02:38 PM
Thanks (Received): 125
Likes (Given): 43
Likes (Received): 905
If it's metal shavings a magnet should pick them up, then you can show the dealer!
Coby7 is offline
post #4 of 12 Old 12-09-2015, 02:39 PM
Likes (Given): 48
Likes (Received): 74
I would let the dealer and Ariens themselves know. Sounds like someone didn't clean the tank out good after it was assembled.
The only damage I could foresee would be the shavings would get caught in the fuel filter. If it didn't have a filter, they could get caught in the carb and probably cause it to run rough or not at all. Either way, I'd clean out the tank, or have the dealer do it.
Cub Cadet 2X 524 SWE
caddydaddy is offline
post #5 of 12 Old 12-09-2015, 03:49 PM
Thanks (Given): 102
Likes (Given): 274
How can you see into the fuel tank? Doesn't it have that screen at the opening?
uberT is online now
post #6 of 12 Old 12-09-2015, 04:03 PM
Thanks (Given): 66
Thanks (Received): 123
Likes (Given): 114
Likes (Received): 157
The fitting that includes the screen can be removed from the tank neck easily. There was already a magnet in my tank that had a small amount of metal particles.
I did not put the screen back in since it is easier to fill the tank without it.
Town is online now
Thanks Cardo111 thanked for this post
post #7 of 12 Old 12-09-2015, 04:29 PM
Likes (Received): 1383
How in the name of ZEUS did metal shaving get in the tank. you must have some metal eating mice around there.
post #8 of 12 Old 12-09-2015, 05:30 PM
Thanks (Given): 82
Thanks (Received): 173
Likes (Given): 424
Likes (Received): 664
very interesting that there was already a magnet in your tank.
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #9 of 12 Old 12-09-2015, 05:34 PM
Thanks (Given): 82
Likes (Given): 424
found it ironic that a member from magnetic hill ( been there for the " up hill drive in neutral numerous times" ) would suggest a magnet !!!
28 " Ariens Sno Tek
Toro CCR ss
post #10 of 12 Old 12-09-2015, 05:40 PM
Thanks (Given): 102
Likes (Given): 274
Cool. I did not know that and am sensing the urge to mod this weekend when it's 60F !!
uberT is online now
