Ariens 28" Deluxe 921030 missing axle c-clip - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 12-09-2015, 06:08 PM Thread Starter
Hello everyone. I just got a new 921030, I was getting it ready for this season by doing:
1. Replaced metal sliders with Ariens poly
2. Adjust the case and sliders to prevent auto turn issues
3. Remove wheels, coat axles with antisieze
Step 3 is where I ran into a problem. One side was different than the other. Each side has the push on retainers, but only one side had the C-Clip retainer that sits behind the outer push on retainer.
Is this normal? Should I get another? Are the outer retainers strong enough to retain the wheel?
JayPaul is offline
post #2 of 5 Old 12-10-2015, 02:55 PM
Thanks (Given): 66
Thanks (Received): 123
Likes (Given): 114
Likes (Received): 157
Yes it is normal for my machine. The parts manual shows the C clip on one side only. I confirmed this with my dealer too.
Coating the wheel axles with anti-seize will probably work fine, but in my experience it reacts poorly with water and balls up and makes a mess. I prefer the water resistant grease. On the wheel to hub interface for my car the silicone dielectric grease resists heat and is unaffected by water where anti-seize is not as effective and just makes a mess.
Good luck.
Town is offline
post #3 of 5 Old 12-10-2015, 04:17 PM
Thanks (Given): 589
Likes (Given): 4358
Likes (Received): 1740
Anti-seize is best used for static close tolerance situations like threads.
Like Town mentions it's not a good choice for stuff that's exposed to the elements as it dries out and flakes off and doesn't have water resistance.
Marine grease or my lube of choice, Mobil 1 synthetic bearing grease IMHO would be a much better choice that will protect your parts better and longer.
Name:	Grease wheel bearing Mobil1.jpg
Thanks Zavie thanked for this post
Likes Zavie liked this post
post #4 of 5 Old 12-10-2015, 07:14 PM Thread Starter
Thanks!!!
Wonder why the c-clip is only supposed to be on one side??
JayPaul is offline
post #5 of 5 Old 12-10-2015, 10:23 PM Thread Starter
Thank you. I redid the job, wiping off the antiseize and applying a nice thin coat of Mobil 1 synthetic bearing grease.
FYI: I realized why there is only one C-Clip. The right side (non-chute side) axle slides off of the inner axle. That C-clip prevents lateral movement. The other side is fixed, so no need for that C-Clip, as you only need to retain the wheel, not the axle as well. Hope this helps someone else.
JayPaul is offline
Thanks Town thanked for this post
