ariens tire upgrade - Snowblower Forum : Snow Blower Forums
post #1 of 21 Old 12-11-2015, 01:08 AM Thread Starter
ariens tire upgrade
will these tires fit on ariens 10000 series 3 bolt rims?
post #2 of 21 Old 12-11-2015, 06:16 AM
Likes (Received): 303
I have the 13 x 5 x 6" xtracs on a 924 series. The pic with the tape measure is misleading by the angle. The very leading edge of the tire is 6 1/2" from the center of axle, yours would be 7.5. Clearance issue may be engagement lever side of your 10,000 series, figure the 15's would sit 1" higher than in my pic of that side. If you have 6" tires now, they'll fit on the rim. Mine are 3 bolt rims also.
Likes db130 liked this post
post #3 of 21 Old 12-11-2015, 08:43 AM
Thanks (Given): 16
Thanks (Received): 86
Likes (Given): 241
Likes (Received): 202
I am using 13x5.00-6 X-tracs on a 10000 series
db130 is online now
post #4 of 21 Old 12-11-2015, 09:48 AM
Likes (Received): 36
the original on my 10954 are 13x5x6 turf saver. 15"s should fit. post update if you get them as I want to put a pair on mine
ctdave is offline
post #5 of 21 Old 12-11-2015, 10:42 AM
Likes (Received): 483
13 inch will fit just right, 15" will make the tractor sit too high, it would still work though. Tractor will move a bit faster too with the 15" tires.
YSHSfan is online now
post #6 of 21 Old 12-11-2015, 12:47 PM Thread Starter
ok i found them on amazon for about 25 bucks a piece so im going to order those, they are actually cheaper then the snow hogs i was looking at before
post #7 of 21 Old 12-11-2015, 12:52 PM
Thanks (Given): 16
I asked about these tires on my 922006 but it must have gotten deleted with no notification tome. Should I have started a new thread on it?
Manfjourde is offline
post #8 of 21 Old 12-11-2015, 01:29 PM
Thanks (Given): 16
Likes (Given): 241
Yes, you should have. Looks like a moderator took care it already though:
https://www.snowblowerforum.com/forum...-922006-a.html
db130 is online now
Thanks Manfjourde thanked for this post
Likes knu2xs liked this post
post #9 of 21 Old 12-11-2015, 03:42 PM
Thanks (Given): 16
Thanks so much!
post #10 of 21 Old 12-12-2015, 10:15 AM
If you're going to mount them yourself prepare for a half day of grunting and swearing. The bead on those 6" X-tracs is VERY tough. I ended up soaking the tires in very hot water with dish soap added. I've done lawn tractor tires several times that were a breeze. They were larger ID (8-12"). I have one of those cheapo HF small tire mounting kits and it still took 2 big guys and several large flat blades to get the final edge of the bead over the rim. You will need to touch up your rims if you painted them after. I have taken a few sets over to the golf course off season and had the repair crew do it for pizza and beer since my first attempt on my set. I highly recommend it for the 6" X-tracs, just FYI.
