Want to replace solid tires on 922006 - Snowblower Forum : Snow Blower Forums
post #1 of 16 Old 12-11-2015, 10:17 AM Thread Starter
Thanks (Given): 16
I am new with these old Ariens - I have a 922006 - with the solid rubber tires. Can I change them to something like these or not?
Manfjourde is offline
post #2 of 16 Old 12-11-2015, 11:09 AM
Thanks (Given): 590
Likes (Given): 4371
Likes (Received): 1743
I'm not sure. Usually the ones with solid tires have a different wheel that doesn't work with a tube or tubeless tire or may even be bonded to the wheel. I dont' know specifically on your Ariens Model.
But you can always look around for someone selling the wheel/tire assemblies off their machine or even a machine with good tires and a blown engine for the wheels. Just need to make sure the shaft diameter matches and that they'd fit your machine.
Sometimes you need to be creative.
Thanks Manfjourde thanked for this post
post #3 of 16 Old 12-11-2015, 11:42 AM
Thanks (Given): 16
Thanks (Received): 86
Likes (Given): 241
Likes (Received): 202
According to this site, yes:
Tire and Wheel Assembly [07124100] for Ariens Lawn Equipment | eReplacement Parts
db130 is online now
Likes Manfjourde liked this post
post #4 of 16 Old 12-11-2015, 12:06 PM
Thanks (Given): 590
Likes (Given): 4371
I started your own thread as this didn't have anything to do with the OP's question.
post #5 of 16 Old 12-11-2015, 03:46 PM Thread Starter
Thanks (Given): 16
Thanks so much! The hard rubber is not so great.
post #6 of 16 Old 12-11-2015, 04:10 PM
Thanks (Received): 195
Likes (Given): 469
Likes (Received): 816
I put these on an early Ariens
Jackmels is online now
post #7 of 16 Old 12-11-2015, 04:20 PM
Thanks (Given): 9
Thanks (Received): 24
Likes (Received): 36
I'll ditto that thought.
I had the same problem, not with an Ariens, but the same principle.....i.e. worn out hard rubber tires on non-pneumatic wheels. It took some scrabbling around, but with some good advice I was given here at the forum and a lot of research on my own, I came up with as good a solution as I'm likely to find for a nearly 40 year old machine.
You might want to check out my thread for ideas.
https://www.snowblowerforum.com/forum...es-wheels.html
Here's another relevant thread on this same topic:
https://www.snowblowerforum.com/forum...-retrofit.html
2003 Toro 826 LE Power Max
1978 Yardman Snowbird 31600-9 (5hp x 24")
* Don't worry about the world coming to an end today. It's already tomorrow in Australia !
ztnoo is offline
post #8 of 16 Old 12-11-2015, 11:59 PM Thread Starter
Thanks (Given): 16
Do you recall which tires and wheels those are?
Thanks you all for the links and help! Speaking if wheels and tires - how do I lock/unlock the differential if this machine has one?
post #9 of 16 Old 12-12-2015, 08:22 AM
Likes (Given): 469
Pretty Sure they came off a 5-22 MTD.
post #10 of 16 Old 12-14-2015, 11:57 PM Thread Starter
Thanks (Given): 16
I haven't pulled the 3 bolt hubs off yet - does the axle have a hole for a pin like in your pic or did you have to drill it?
Also any chance you have a model number or the tire size on those side walls?
