ariens gear box - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 12-14-2015, 09:35 AM Thread Starter
Thanks (Given): 121
Likes (Given): 269
Likes (Received): 6
ariens gear box
I have a junk ariens 924048 7 hp snow blower . I am changing out the fan shaft bearing . It moves back and fourth 1/16 of a inch . I would loke to all so change the gearcase flange bushing . the fan is rusted to the shaft . Is the gear one piece to the shaft Could I change the flange bushing # 9 by just taking the gearcase apart . I all so need a spring idler for the puller . part 083094 . This is a sad machine . Thanks guys . moter H70 -130210 E
ID:	67218   Click image for larger version
ID:	67226   Click image for larger version
eyeboltman
Eyeboltman is offline
post #2 of 8 Old 12-14-2015, 11:13 AM
Thanks (Received): 195
Likes (Received): 816
You'll need to remove the impeller from the shaft to change #9 Bushing. I've been able to remove impellers with a oxy-ascy Torch and some patience. You may need the use of a Press if it is Rusted Badly. GL
Jackmels is online now
post #3 of 8 Old 12-14-2015, 11:37 AM
Likes (Received): 280
those can be real muthers to get off when they rust on...... heat and love taps are the only way. You can try the candlewax method - heat it up good and touch the candle onto it such that it can suck some wax into the joint..... sometimes it works.
post #4 of 8 Old 12-14-2015, 11:47 AM
Likes (Received): 483
I was able to free up 2 really seized/frozen augers on one of my Yamaha YS828 yesterday.
It takes patience first of all.
The aproach that i took was to heat (using an oxy/accet torch) the augers close to red hot and cool them off with cold water. I did this in a circular motion doing one side first, then 180 degress, then 90 degrees and another 180 degrees to try to prevent the shaft from warping. It took 2 attemps on each one but after I was able to spin them on the shaft one full turn they came out without major issues.
post #5 of 8 Old 12-14-2015, 01:14 PM
Likes (Received): 39
I would probably clean the end of the shaft, then get it in a press and heat it quickly, just enough to get it to move.
nt40lanman is offline
post #6 of 8 Old 12-14-2015, 06:10 PM
Thanks (Received): 98
Likes (Received): 260
If you don't have an acetylene torch, your best bet you be to drip some PB Blaster thru it for several nights, while tapping it to vibrate some of the liquid inside, then get out the BFH. i was also able to help by putting the shaft inside a piece of pipe and use the Big Hammer. It takes time and patience, but a torch is your best friend for this.
RIT333 is online now
post #7 of 8 Old 12-14-2015, 08:33 PM
Likes (Received): 42
Loud, bad language, heat and a hand sledge. Wear gloves and ear protection. Search for a suitable donor machine. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
8 hp MTD hybrid plow
motorhead64 is offline
post #8 of 8 Old 12-15-2015, 10:42 AM Thread Starter
Thanks (Given): 121
Likes (Given): 269
Likes (Received): 6
Thanks guys . Don't sound like fun .
eyeboltman
