Ariens Pro 26 (26005) vs Ariens 28 Deluxe (921030) - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 12-14-2015, 02:06 PM Thread Starter
I'm looking at buying an Ariens blower and was wondering if people had opinions on the relative quality of an older Pro 26 (in excellent condition) vs a new 28" Deluxe.
Are these machines comparable? Are there significant advantages to the Pro line? I know that I may have to install the two-belt upgrade kit the Pro 26.
zzzman is offline
post #2 of 5 Old 12-17-2015, 10:28 AM
Thanks (Given): 589
Likes (Given): 4358
Likes (Received): 1740
to the forum zzzman
Don't have an answer for you but here's a
post #3 of 5 Old 01-31-2016, 11:49 PM
While this won't help you, you brought the 2 belt issue to my attention. With that being said, I have put my Pro 26 through a lot in New England since I got it in 2011. I have to say it is a beast. I will be going out to look at my belts now to see what's up. Thanks for enlightening me. I love the Pro 26.
govenatorx is offline
post #4 of 5 Old 02-02-2016, 07:07 PM
Likes (Received): 13
What is the HP on the older Pro? I had a newer Deluxe 28 (4 yrs old) and just got rid of it. In my opinion it is a well built blower but under-powered with a 250cc. I would take a close look at the Pro, especially if it has a larger, heavier frame as well as larger engine.
hfjeff is offline
post #5 of 5 Old 02-02-2016, 07:32 PM
Thanks (Given): 172
Thanks (Received): 337
Likes (Given): 476
Likes (Received): 836
I have a 1024 Pro, from 2000, I believe (bought it used). It claims 10hp, it's a 318cc Tecumseh OHV engine.
I have about 2 seasons on it, but one was the record-breaking New England winter last year. So it definitely got a workout.
I thought it did great. It was reliable, fortunately, and performed well even in the 2-foot storms.
At times the engine would slow some under a heavy load, but at the end of the season I discovered the governor wasn't actually opening the throttle plate all the way, even as the engine slowed. I replaced the governor spring, per what I read online, and re-adjusted the governor, now it holds RPM better, and opens the throttle further. So I'm getting to take better advantage of the engine's power.
I had an ST824 previously, from the early 90s. 8hp 318cc flathead Tecumseh. I was curious what the "Pro" would offer.
Benefits I can think of that aren't necessarily just a result of the Pro being a newer machine:
- more powerful engine for the same clearing width
- cast iron gearbox vs aluminum
- heated handgrips (I really appreciated this last year)
- thicker skid shoes
- headlight
It also has the tall chute and quick-crank chute control, but those simply evolved between the two eras, I think. They both have differentials, which I think are great.
To be honest, any other differences between the two machines are not obvious. I was kind of expecting there might be more changes in a Pro model. If the frames are significantly different, it didn't jump out at me, but both are large-frame (924) machines.
I'm not complaining about the machine, mind you, it's been great!
But having dual auger belts would be nice, for instance. For a 24" bucket, it's apparently less critical (mine was fine through a hard winter). But load up the engine more with a wider bucket, and it might start chewing up belts. Heck, my 8hp 26" MTD had dual auger belts.
