Missing ground prong on tecumseh starter button - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 12-28-2015, 06:19 PM Thread Starter
Thanks (Given): 16
Likes (Received): 11
Hi all,
I scored a deal on a vintage starter for the 6hp tecumseh on my 910019. I just realized that the ground prong on the starter button has long since broken off. Are there any dire safety issues I should be worried about? I know the first generation starters (the ones with the prongs mounted to the starter itself) were not grounded. Could I add a ground prong by popping open the button housing?
THanks in advance.
Stang is offline
post #2 of 11 Old 12-28-2015, 06:56 PM
Thanks (Received): 173
Likes (Given): 414
Likes (Received): 663
i dont think my old tech estart has a ground prong? could be wrong tho, will have a look tomorrow if need be.
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #3 of 11 Old 12-28-2015, 07:01 PM
Thanks (Given): 587
Thanks (Received): 767
Likes (Given): 4352
Likes (Received): 1734
I know what you need but I can't find one anywhere.
I guess you'd need to go to a hardware/big box and pick up a male and female end to an extension cord and a foot of 3 conductor wire. Make a 6" or so extension cord but take the green ground wire from the male and physically ground it to the starter motor. So the black and white wires run female against the starter to male hanging down waiting for the extension cord. The green would be connected to the ground lug of the male end hanging but it would not go to the female at the starter but to the starter itself.
That would keep you safer as would making sure the circuit you use is GFCI protected or you put in a GFCI outlet if the circuit isn't protected with one in you breaker box.
post #4 of 11 Old 12-28-2015, 07:03 PM
Thanks (Given): 587
Likes (Given): 4352
The really old machines will only have the two. I assumed his was originally equipped with the ground prong and it was broken off or missing.
post #5 of 11 Old 12-28-2015, 07:22 PM Thread Starter
Thanks (Given): 16
This is the type of starter box that I have (taken from an ebay auction):
The ground prong on the bottom is what is missing.
Stang is offline
post #6 of 11 Old 12-28-2015, 07:25 PM Thread Starter
Thanks (Given): 16
Interesting. Would there be any way to replace the missing prong on the unit itself so I can avoid dangling wires? What's the "thing I need but you can't find anywhere"?
Thanks!
Stang is offline
post #7 of 11 Old 12-28-2015, 07:27 PM
Likes (Given): 414
you are probably correct, i used an old two prong cord that had a tab on it that wouldnt allow it to plug into the starter, just cant remember if it was because of the ground prong, or it just wouldnt fit into the receptacle on the starter, anyhoo, i trimmed the tab off and all was good.....using a GFI outlet.
28 " Ariens Sno Tek
Toro CCR ss
post #8 of 11 Old 12-28-2015, 07:40 PM
Likes (Given): 414
hmmm, i think you may be able to go to your local hardware store and buy a male plug end, and possibly rob the ground prong from it.....would be worth a look !
28 " Ariens Sno Tek
Toro CCR ss
post #9 of 11 Old 12-28-2015, 08:50 PM
Thanks (Given): 172
Likes (Given): 450
Likes (Received): 1029
Or, just replace the whole dang cord with a short one you can make yourself. Just find a heavy draw momentary switch and stick it in there. Hour long job. Heck. You could even use a rocker switch.
post #10 of 11 Old 12-28-2015, 09:44 PM
Thanks (Given): 587
Likes (Given): 4352
The opposite of this guy. You need something "Male" that will take the make ground lead external so you can ground it to the starter.
These are all "Female" as far as taking the ground from the female side and making it external.
There are a number of different ways to do it and you can get 4-5 feet of cord and really extend it up the handle bars so you wouldn't need to bend over to plug it in, tie wrap it.
