Chute moves by itself while plowing the snow. - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 12-29-2015, 11:45 AM Thread Starter
Just got the chance to use my Ariens Deluxe 28 for the first time, is there a way where I can tighten up the chute so it won't move left to right or vice versa while removing snow?
kercha83 is offline
post #2 of 3 Old 12-29-2015, 01:29 PM
liftoff1967's Avatar
Thanks (Given): 36
Thanks (Received): 45
Likes (Given): 65
Likes (Received): 94
Assuming this is a newer model, there will be a vertical fastener on the underside of the black plastic cover (the one that holds your extra shear bolts). If memory serves me correct, a 9/16 wrench will be needed. You will see a spring betwixt the nut and the worm gear. Give the nut a twist with said 9/16" wrench to either loosen or tighten.
That will solve your wandering chute issue.
liftoff1967 is offline
post #3 of 3 Old 12-29-2015, 02:18 PM Thread Starter
thank you, i will do this when I get home.
kercha83 is offline
