Input Requested on repair vs new - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 01-02-2016, 12:47 PM Thread Starter
Hi there. A new member as of today.
I wanted to get your advice on our existing Ariens 522.
The snowblower is several years old and served us well. Always started and ran great. However, this winter we started to see several things going wrong.
1. Gas is leaking from the bottom of the carburetor. We are not handy when it comes to engines, but gas is leaking around a bolt on the very bottom. I tried tightening, but no luck.
2. The start rope is starting to fray and about to break.
3. The snow chute will not stay in place. I tried to figure out how to tighten a spring or something, but cannot find how to get to that location.
We live in Iowa and snow is usually pretty manageable. It's always done well except towards the engine of the driveway due to snow trucks piling it up. Our driveway is about 50 feet long, by 30 feet wide and couple of sections of a sidewalk.
We are open to a replacement, but wanted your input on if it makes sense to repair. My guess is we'd need to take it somewhere.
For a replacement we looked at the 24 compact but to me is bigger than we'd ever need. However, the auger would be great for the end of the driveway.
Thoughts or suggestions for a different model? Doesn't have to be Ariens.
Thanks.
iFalcon is offline
post #2 of 14 Old 01-02-2016, 01:03 PM
Thanks (Given): 590
Likes (Given): 4367
Likes (Received): 1742
to the forum iFlacon
The 24 compact would be a wonderful machine but the one you have wouldn't take too much time or $$ to fix if you're willing to take the time.
It would also be worth more if you chose to use it for a trade in or sell (craigslist) and apply the cash to the purchase of the compact !!
Depending on how "not handy" you are will determine the course you take.
You can get a new carb for around $20 in most cases or a rebuild kit. It's likely a bad gasket at the bottom of the bowl where that screw is.
Starter rope can be purchased at Homedepot, autoparts, hardware, ebay, ...
Not that involved to replace.
There is better rope available but this is easy to get: http://www.homedepot.com/p/Power-Car...g&gclsrc=aw.ds
On the chute the crank rod usually goes through an eyebolt that usually has a rubber grommet. If you take a pliers and gently crush that eyebolt applying a bit more pressure to the rod it can hold position better.
Not sure how your 522 is set up, can you post the actual model number and/or a photo of the crank rod ??
post #3 of 14 Old 01-02-2016, 01:09 PM
Likes (Received): 39
Most here would say fix it. Your problems are all minor and a decent repair shop could fix it up fairly easily. Any blower will end up that way after a while and you don't want to buy a new one every few years just for maintenance items.
And ALWAYS buy Ariens
nt40lanman is offline
post #4 of 14 Old 01-02-2016, 01:11 PM Thread Starter
This is my model 938016.
iFalcon is offline
post #5 of 14 Old 01-02-2016, 01:13 PM Thread Starter
Where is the best place online to buy a carb kit? Sorry for the dumb questions.
iFalcon is offline
post #6 of 14 Old 01-02-2016, 01:18 PM Thread Starter
Also, this model doesn't have a chute crank rod. It has a handle on the chute and manually rotate it. I can't figure out how to take the bracket discharge chute rotation removed from the chute discharge.
It's not clear to me if there is something in there to tighten.
iFalcon is offline
post #7 of 14 Old 01-02-2016, 02:16 PM
You could always buy the new compact and use that why you fix the little things on your single stage. If you have the storage having both is good since they both have their advantages. Also nice to have 2 in case one breaks. The carb might just need a new gasket on the bottom. A gasket kit is like $3 if it runs fine other than the leak. The rope is also easy, however single stage machines are usually harder to get to since they have so many covers.
If your machine also has an electric start then the rope isn't in dire need of needing replaced. If it ever breaks you can use the electric until it gets fixed.
For buying parts you can find a local shop (small independent or something like home depot/tractor supply company for basic maintenance) or go someplace like amazon, ebay, mfgsupply or jackssmallengines. For small things like the gaskets it might be better to buy locally since you save on shipping costs.
post #8 of 14 Old 01-02-2016, 02:30 PM
Likes (Received): 280
I say fix it - they get so little hours on them around here, it's not usually cost effective to replace them if you have good quality machines.
As for your chute - I think it's probable you need the spring identified as #10 here:
Ariens 938016 (SS522E) - Ariens 22 Snow Blower, 5hp Tecumseh (SN: 000101 & Above) Auger And Discharge Chute Diagram and Parts List | PartsTree.com
Take a look at the diagram and see what else might need attention. If you are near Cedar rapids, I do repairs if you can't handle them. Most of what you have should be pretty much DIY. The carb can be frustrating to some people and I understand that. Watch some of the video's and see what you can do....
post #9 of 14 Old 01-02-2016, 04:10 PM Thread Starter
Bad69cat ..
We actually live in Des Moines.
iFalcon is offline
post #10 of 14 Old 01-02-2016, 04:16 PM
Thanks (Given): 102
Likes (Given): 274
Yeah, I'd probably service that machine up, too. Not very old.
You have two service options: Ariens dealer or your local small engine repair guy.
uberT is offline
