hard starting - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 01-08-2016, 01:48 PM Thread Starter
Likes (Received): 39
hard starting
I'm working on a 924116 with an 8hp Tec. It won't start with the pull rope. The carb is getting gas, I took the bowl down and wired out passages, the primer is airtight, it even drips gas when you prime but it'll only start if you spin it over with the electric starter while hitting the primer. Once running, it runs fine. Any other suggestions?
nt40lanman is offline
post #2 of 11 Old 01-08-2016, 03:00 PM
Thanks (Received): 195
Likes (Given): 469
Likes (Received): 816
Ignition. Probably needs points cleaned or replaced. Just dealt with the same issue today. First check the magnets on the flywheel. If it's not points ignition, probably bad coil.
Jackmels is offline
post #3 of 11 Old 01-08-2016, 03:12 PM Thread Starter
It's a fairly new machine and I assume it has electronic ignition. I'm going to replace the plug and test the spark.
post #4 of 11 Old 01-08-2016, 03:21 PM
Thanks (Received): 87
Likes (Given): 57
Likes (Received): 269
With full choke on, and priming it till you see gas dripping from the carb, (should only requrie 2-3 primes for that) it won't even hint at starting with the pull rope? What about with 3/4 choke, 1/2 choke, or 1/4 choke?
GoBlowSnow is offline
post #5 of 11 Old 01-08-2016, 04:10 PM
Thanks (Given): 590
Likes (Given): 4366
Likes (Received): 1742
Sounds like you might need to check the spark with a spark tester. If it's weak at slow speed it might be the reason you need to use the electric to spin it faster to get a stronger spark.
post #6 of 11 Old 01-08-2016, 07:29 PM
Thanks (Given): 275
Thanks (Received): 330
Likes (Given): 3346
Likes (Received): 679
Have you done a compression test on the motor? Could be a valve leaking and the electric start spins it fast enough to create enough compression to overcome the loss when pulling with the recoil.
Likes classiccat, 43128 liked this post
post #7 of 11 Old 01-08-2016, 07:59 PM
Thanks (Received): 39
Likes (Given): 53
Likes (Received): 100
Had the same trouble this yr with my blower. For me it was old gas.
Scott
69 ariens
toro 721r
toro 926 hd oxe
69ariens is offline
post #8 of 11 Old 01-08-2016, 08:12 PM
Likes (Received): 280
being that it's a newer machine - I would be looking at the choke a bit closer. If it accessible with the cover off be sure it really is closing. If no start - try covering it up even more with tape or something and see if that helps.....without doing anything different. Some of those non-adjustable carbs are just finnicky
post #9 of 11 Old 01-09-2016, 08:10 AM Thread Starter
I *think* it was empty when it got here and I put gas in it, but I could be wrong. Maybe I'll drain it.
post #10 of 11 Old 01-09-2016, 03:15 PM Thread Starter
I put a plug in, drained and filled the gas. It was already warm so I left it running a half hour. Then I let it cool a while and it starts great now. I'm betting bad gas.
Likes Grunt, classiccat liked this post
