Oil changes synthetic vs regular - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 01-11-2016, 09:23 PM Thread Starter
Likes (Received): 12
how often do u guys change ur oil in ur Ariens? i know the manual says after first 5 hrs...how often after? do u guys use synthetic? does it lengthen the times in between oil changes?
SNOWJOB1125 is offline
post #2 of 14 Old 01-11-2016, 09:29 PM
Likes (Received): 39
I change once a season unless its like last winter. I use regular oil.
nt40lanman is offline
post #3 of 14 Old 01-11-2016, 09:36 PM
Thanks (Given): 102
Likes (Given): 267
Once a season should be adequate for most of us, especially if using a syn oil.
uberT is offline
post #4 of 14 Old 01-11-2016, 10:10 PM
Thanks (Given): 581
Thanks (Received): 757
Likes (Given): 4285
Likes (Received): 1710
Once a season and I use Mobil1, 0-40 that I get at Walmart.
Name:	Oil mobil 1 european formula.jpg
post #5 of 14 Old 01-11-2016, 10:19 PM
Thanks (Given): 14
Thanks (Received): 17
Likes (Given): 36
Likes (Received): 31
+ 1
250cc B&S (1150 ft lbs)
Loco-diablo is offline
post #6 of 14 Old 01-11-2016, 10:38 PM
GustoGuy's Avatar
Thanks (Given): 50
Thanks (Received): 76
Likes (Given): 69
Likes (Received): 135
AMSOIL synthetic is what I use. Had the best luck using AMSOIL synthetic I currently have a 2003 Hyundai Elantra with 395000 miles on it. It still has the original engine and transmission it's never been replaced. Runs great and back a few years ago I had the valve cover gasket replaced. Mechanic who replaced the gasket said the inside of the engine was immaculate with no sludge deposits whatsoever. People complain that synthetic oil is way too expensive. I change my oil in my snow blower once the season Too. Couple extra dollars is pretty cheap insurance the way I look at it it's only going to cost a few dollars more for your snow blower each season at most.
GustoGuy is offline
post #7 of 14 Old 01-11-2016, 11:24 PM
SnowG's Avatar
Thanks (Given): 51
Thanks (Received): 36
Likes (Received): 63
Once a year at end of season. Synthetic is preferred.
SnowG is offline
Likes Elt31987 liked this post
post #8 of 14 Old 01-11-2016, 11:40 PM
94EG8's Avatar
Thanks (Received): 48
Once a year at the beginning of the season. You'll tend to get a lot of condensation sitting over the summer so I just leave it and change it in the fall.
94EG8 is offline
post #9 of 14 Old 01-12-2016, 02:51 AM
oneacer's Avatar
Thanks (Received): 144
Likes (Received): 524
I moved over to a Syn 5-30 w years ago on all my small engines, new and old, as you can see, Briggs & Stratton suggest it also for the widest coverage. Change it once a year. The biggest downfall on the lifespan of small engines is lack of maintenance.
FAQ: Lawn Mower Oil Type & Capacity | Briggs & Stratton
oneacer is online now
Likes Terrance liked this post
post #10 of 14 Old 01-12-2016, 10:05 AM
Normex's Avatar
Likes (Received): 82
As the previous posters mentioned change it once a year and no difference if at end of season or beginning since if any condensation would occur, just running the engine for 15 minutes will dissipate any condensation.
As for oil type syn. vs reg., I use synthetic in all my engines whether car or small engines for the simple fact that the synthetic molecules are much smaller therefore filling microscopic voids which results in a better sealed components ei; piston rings, valve guides, crankcase etc. resulting in a much longer cleaner oil.
Conventional oil are ok too but it gets dirty faster since the bigger molecules allows the carbon to soil the oil black over time.
So my preference is Mobil Synt. 5w-30
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
