Deluxe 30 pull cord not working - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 01-19-2016, 12:57 PM Thread Starter
Hi. I have a Deluxe 30 (S/N: 108XXX). When pulling on the start cord it will pull out and retract on its own but will not engage. Ended up using the electric start for the first time for the storm we just had. What is the best way to investigate what is wrong and repair? Having a hard time locating anything online regarding this.
timv is offline
post #2 of 10 Old 01-19-2016, 02:11 PM
Thanks (Given): 31
Thanks (Received): 15
Likes (Given): 67
Likes (Received): 16
First OFF welcome to the SBF site!
Most Likely The Dogs (ratchet mechanism) are hanging up. They may perhaps be stuck in the grease.
I would try pulling cord and let it snap back (spring back) from about half length or more of the cord. To see if the dogs spring back in place.
Perhaps very lightly tap housing with a rubber mallet??
Otherwise I would take housing apart, (three screws) and visually inspect.
Good luck!
Ariens Deluxe28+ AX414cc
Ariens ST824
Ariens 1970
Honda HS521
Cub cadet SS
Snowbird
Biketrax is offline
post #3 of 10 Old 01-19-2016, 02:33 PM
Likes (Received): 280
Agree - what happens when you yank the cord is that it thorws out 2 little tangs that enguage the flywheel. there is a couterwound spring that should pull the handle back in and drop the 2 tangs. You might try spraying a little slicone in there also..... it will help lubricate the area and repel water also.
post #4 of 10 Old 01-19-2016, 02:37 PM
Thanks (Given): 590
Likes (Given): 4366
Likes (Received): 1742
This might help show you what's going on in there.
post #5 of 10 Old 01-19-2016, 04:40 PM
Could be frozen with ice too.
post #6 of 10 Old 01-19-2016, 04:53 PM
yeah - especially if it was windy out when your blowing. I have had 'em ice up on me before.
post #7 of 10 Old 01-20-2016, 08:37 AM Thread Starter
Thanks all for the quick replies. Seems straigh forward enough. Will take it apart and look at it when it warms up a bit. -17 C here today with wind chill.
timv is offline
post #8 of 10 Old 01-20-2016, 08:42 AM
Thanks (Received): 112
Likes (Received): 298
If you were a little nylon starting pawl, wouldn't you be hiding at that temperature?
Work fascinates me.
skutflut is offline
post #9 of 10 Old 01-20-2016, 08:45 AM
Thanks (Given): 14
Thanks (Received): 17
Likes (Given): 36
Likes (Received): 31
+1 .. This happened to me several years ago. It was frozen.
250cc B&S (1150 ft lbs)
Loco-diablo is offline
post #10 of 10 Old 01-20-2016, 12:40 PM
Thanks (Given): 590
Likes (Given): 4366
Might want to try a hair dryer on it before you take it apart.
Likes bad69cat liked this post
