What Am I Missing: Impeller Won't Turn - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 12-16-2013, 08:24 PM Thread Starter
Arien's Model 926008 Impeller doesn't turn. It's not froze up & belt looks to be in good used condition. Have belt cover off, reach up and engage impeller lever,the
idler/tensioner pulley moves in and looks like it's moved sufficiently to tension the
impeller drive belt but the bloody thing doesn't turn the impeller. Man it's cold working out but no choice on that. Ok if you've any suggestions I'd love to
hear-em.
Many Thanks,
rabie
rabie is offline
post #2 of 3 Old 12-16-2013, 10:58 PM
Thanks (Given): 589
Likes (Given): 4362
Likes (Received): 1741
Any chance the shear bolt(s) for the impeller are missing ??
Does the auger still turn
post #3 of 3 Old 12-16-2013, 11:13 PM
hear-em.
Many Thanks,
rabie
Crack open the owner's manual and check the auger cable and idler adjustments. Also check the roll pins in the impeller/fan. Make sure they are not sheared. Does the impeller/fan not turn, or is it the augers?
This is an older model 926,XXX. If you ever replace the auger belt, you can upgrade this unit to the current dual belt setup that became standard equipment in 2008 or so. It includes the belts, pulleys, idler arm, etc. p/n 72600700, list price is $55.
Snowmann is offline
