Help!!! Snowpocalypse II is almost here! - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 01-20-2016, 08:26 PM Thread Starter
Likes (Received): 8
Okay, I fired up my recently new hydro-Pro this evening after sitting all summer. I purchased it new March of 2014. Ran great in 2015. Presently has 12.5 hours on it.
This evening I filled the tank and started it. It started no problem but it does have a fuel leak at the carburetor. It appears to be coming from the square duct that drops below the carburetor. Attached is a picture showing the area I think it is coming from.
Please note that it only stops leaking when I turn the fuel valve off.
Does anybody have any idea what is going on?
Matt
Ariens Hydro Pro 36
MattM is offline
post #2 of 7 Old 01-20-2016, 08:35 PM
Likes (Received): 39
Sounds like a float valve problem. The round bowl in the lower right has the float valve in it. I would leave the fuel off, unscrew that drain bolt over a can, and poke up in there with a paperclip to move the float up and down a bit, then re-assemble and test it. If that doesn't work, you can shut the gas off again and remove the bolt in the center of that bowl and work on the float valve, cleaning out anything holding it open.
nt40lanman is offline
Likes ddip214 liked this post
post #3 of 7 Old 01-20-2016, 08:38 PM
Thanks (Given): 72
Thanks (Received): 398
Likes (Given): 183
Likes (Received): 931
I had a gas leak due to a sticky carb float..
I sucessfully fixed it using seafoam..
(I should note I cant be 100% sure it was the seafoam that un-stuck it! it *might* have been something else..but I am 99% convinced it was the seafoam that un-stuck it)
my seafoam story:
http://gold.mylargescale.com/scottyc...html#question4
post #4 of 7 Old 01-20-2016, 09:26 PM Thread Starter
Likes (Received): 8
Thanks nt40lanman,
That did the trick! It took longer to write the post than fix it.
Matt
Ariens Hydro Pro 36
MattM is offline
Likes bwdbrn1, 1894, ddip214 liked this post
post #5 of 7 Old 01-20-2016, 09:59 PM
Thanks (Received): 143
Likes (Received): 297
Another suggestion, shut the machine down (for the night,week, month) with the fuel shut off. Use the kill switch when you want to go warm up, grab a refreshment, or go inside to take care of business.
Likes cfuller3, RedOctobyr liked this post
post #6 of 7 Old 01-21-2016, 06:26 AM
Thanks (Given): 174
Thanks (Received): 342
Likes (Given): 480
Likes (Received): 849
This is how I shut mine down too, closing the fuel shutoff and letting it run until it dies. I also always add stabilizer to my gas, even in the middle of the season.
post #7 of 7 Old 01-21-2016, 06:53 PM
Originally Posted by MattM View Post
Thanks nt40lanman,
Matt
I love fixin stuff and I love helpin people fix stuff!!!
Thanks MattM thanked for this post
Likes dbert, Clearview60 liked this post
