Belt cover on Ariens 28" model 921030? - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 01-23-2016, 06:34 PM Thread Starter
Hi,
I just bought a brand new Ariens model 921030 from Home Depot that I, unfortunately, had to assemble myself. I just used it for the very first time and found that the snow doesn't throw very far at all. The troubleshooting info in my manual says to adjust the Attachment Clutch/Brake. The first step before making this adjustment, however, is to "disconnect the spark plug wire", with the next step being to "remove belt cover". Sounds easy enough, IF I knew WHERE the "spark plug wire" and the "belt cover" were. I am not a mechanic, nor do I have the slightest clue what a spark plug even looks like, nevermind a spark plug wire. That said, I'm beginning to think that I'm the only person on earth that doesn't know where the spark plug or it's wire are, as even the "changing the spark plug" section of the owners manual doesn't have a diagram to showing WHERE that spark plug is located so that we can change it. Crazy, right? Anyway, I have read thru every manual I have for this thing, and am now 3 hrs into excruciating internet searching trying to find a diagram somewhere that will declare something as being the "spark plug wire" and "belt cover" but I'm at my wit's end. Can anyone tell me how to find these 2 things? There's a huge snowstorm whipping around outside my door here in Boston right now and I need my snowblower to BLOW SNOW already.
Thanks in advance for any help and or guidance that anyone might be able to provide to me.
Chris33 is offline
post #2 of 7 Old 01-23-2016, 06:47 PM
Likes (Given): 9
Likes (Received): 12
Pictures in your Owners manual would be quite handy, here's some pictures. Diagram F, #34 is your spark plug boot. It'll be on the left hand side of the engine, as viewed from the rear. Diagram G, #7, is the belt cover. The belt cover is in front of the engine. Hope this helps:Ariens 921030 Parts List and Diagram - (100000 - ) : eReplacementParts.com
Clipperskipper is offline
post #3 of 7 Old 01-23-2016, 06:53 PM
Older snow blowers had the spark plug right on top and easy to find. A lot of newer engines have so many plastic covers on all the parts that everything is hidden. Removing the spark plug wire is done for safety reasons. Adjusting the belt could involve turning the engine so they just want to make sure there is no way for it to start. The belt cover is usually held on by 2 or 3 screws. It is most likely a black plastic dome/tent thing on the top of the machine between the engine and the discharge chute.
Here is our recommended youtube mechanic and some auger belt adjustment videos. Don't recall any Ariens specific ones, but all of them are basically the same.
https://www.youtube.com/user/donyboy...ry=belt+adjust
And this might help you learn how things are put together.
post #4 of 7 Old 01-23-2016, 08:07 PM Thread Starter
Thanks so much for the quick responses. I have located the belt cover but still have yet to be able to figure out where this spark plug wire thing is. I see a big black rubber tube-type thing that seems to be plugged in under a big black box that sits directly behind (and a little on top of) the thing that the Choke Control knob is attached to. Standing behind machine its on the left side as one of you said, but it's not a "wire" really, its more of a fat rubber tube thing that plugs in under the big black box. Is that the spark plug wire? If so, how do I unplug it? Do I have to get this black box off first? I'm so confused.
Thanks again for the help and for your super quick responses. I really appreciate it!
Chris33 is offline
post #5 of 7 Old 01-23-2016, 08:28 PM
Thanks (Given): 82
Thanks (Received): 173
Likes (Given): 421
Likes (Received): 664
the spark plug/wire is hidden behind the "black box", you will have to remove it to see what you are looking for. google spark plug boot, there are many different variants, but you will see what it is/basically looks like.
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #6 of 7 Old 01-23-2016, 08:31 PM
Thanks (Received): 195
Likes (Given): 469
Likes (Received): 816
You don't need to remove the spark plug wire to do this adjustment.
Jackmels is offline
post #7 of 7 Old 01-24-2016, 10:32 AM
Before you do a lot of (maybe unnecessary?)work. Start the machine,engage the impeller,then look down the shoot. With the throttle on high,the impeller should be turning at a pretty good clip. If it's not,then-your auger drive belt is not tight enough. If you had to put this machine together,(of course I don't know to what extent), you should have an idea how to adjust(increase tension)this belt. This sounds more likely the problem to me.
Plugger49 is offline
