One of the reverse gears does not work.... - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 01-24-2016, 04:52 PM Thread Starter
Cool One of the reverse gears does not work....
UPDATE ON THIS 2/4/2016
It was a minor adjustment as you guys mentioned!!!
Al is well now and both reverse gears are working...
Just a adjustment on the GEAR SELECTOR /SPEED SELECTOR
Hi first off I am new here , and just survived the snow in the NY area!!!!
I have a ST24 920014 One of the reverse gears doe not work but the other one does...
Could it be a simple adjustment of the gear thingy?
take it easy on me I am new
Ariens ST24 920014
TunaTaint is offline
post #2 of 11 Old 01-24-2016, 04:53 PM
Thanks (Received): 112
Likes (Received): 297
Probably a simple adjustment of the gear thingy.
Work fascinates me.
skutflut is offline
post #3 of 11 Old 01-24-2016, 04:59 PM Thread Starter
lol the "clutch arm" ?
Ariens ST24 920014
post #4 of 11 Old 01-24-2016, 05:14 PM
If everything else is working, forward and one reverse, and the wheels are turning, the clutch mechanism is probably ok.
Check Page 27 of your manual for instructions on adjusting the speed selector. Might be something is a loose. Did you notice if any of the forward gears are not correct, like too fast or slow?
Manual is here, but Im sure you have yours close at hand....
Speed Selector Adjustment - Ariens 920014 COMPACT 24 LE Owner's/operator's Manual [Page 27]
Work fascinates me.
skutflut is offline
post #5 of 11 Old 01-24-2016, 05:35 PM
Thanks (Given): 165
Thanks (Received): 333
Likes (Given): 457
Likes (Received): 818
You say one of the reverse gears doesn't work. Which one?
If you have reverse 1, and reverse 2, where 2 should be faster, which doesn't work?
If reverse 1 doesn't work, then you probably need to adjust the gear selector linkage length. I'd follow the instructions that skutflut linked to.
If this linkage is adjusted wrong, it can make all of your either forward, or reverse, speeds too fast. If all the forward speeds are too fast, then reverse 1 might not move at all. And if all the reverse speeds are too fast, then forward 1 might not move at all.
Start with adjusting the linkage, and see how it goes.
post #6 of 11 Old 01-24-2016, 05:43 PM Thread Starter
Thank you guys!!!! I had a feeling that all this time soemthing was of... I have had the blower for 2 season now so I am thinking initially when i set it up I mgiht have made mistake...
Ill play with the adjustments... I have sneaky suspicion it is that.
ill report back!!!!
Ariens ST24 920014
post #7 of 11 Old 01-24-2016, 05:49 PM
ill report back!!!!
Make sure the engine is off while you are playing with the linkages. Don't want to leave anything behind in the machine, like fingers.
Work fascinates me.
skutflut is offline
post #8 of 11 Old 01-26-2016, 10:29 AM Thread Starter
Ok here is the update:
I adjusted the speed selector as per manual and Reverse 1 is going in forward slow and reverse 2 is actually going in reverse,,,
All the other forward gears work.....
just R1 is going "forward"
any advice?
Ariens ST24 920014
post #9 of 11 Old 01-26-2016, 11:39 AM
any advice?
Either your adjustment is still off or something is loose/bent.
post #10 of 11 Old 01-26-2016, 11:49 AM
Thanks (Given): 585
Thanks (Received): 761
Likes (Given): 4316
Likes (Received): 1717
You need to adjust the linkage until the friction disc is on one side of the driving plate's center for the first gear and on the other side of center for the first reverse gear.
Presently you have it adjusted so that it's on the same side of center for first and first reverse and only goes to the other side in the second reverse.
If you're doing it according to the manual something is either very worn or might be bent.
The video might help:
Likes LET-UT liked this post
