Popping sound - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 01-25-2016, 08:54 AM Thread Starter
Popping sound
Hello to all. I have a deluxe 28 (921035) with the polar force 250cc. Got it new Dec.2013. Never had a problem till this year. Starts right up but get shuddering and popping sound. Did tune up and ran great. Yesterday clearing snow runs rough on idle, sputters and pops on full throttle. Under load runs great, no sounds at all. Only thing I did different is I used reg. Treated gas where I always used hi test in the past. Dealer said to not use high test. New gas with startron . Have another blower worked great with same gas. Starts on first pull. Stumped. Didn't change gas filter but wouldn't run perfect under load if it was clogged. Plug is clean and dry. Any ideas would be appreciated. Don't want to bring to dealer incase we get more snow.
Jim L.I. is offline
post #2 of 13 Old 01-25-2016, 09:13 AM Thread Starter
Just to add. Did tune up last summer, and started it last month. Ran great. Thanks
Jim L.I. is offline
post #3 of 13 Old 01-25-2016, 09:29 AM
Thanks (Given): 589
Likes (Given): 4362
Likes (Received): 1741
I'd try a different plug just in case the conductor cracked inside the shell or something else happened that isn't visually apparent.
Might want to pull the bowl off the carb and see what's in there and if the float looks ok.
post #4 of 13 Old 01-25-2016, 10:02 AM Thread Starter
Hi, put a brand new plug in. Will look at today. Maybe take bottom of carb off. Don't want to open a can of worms. Thanks
Jim L.I. is offline
post #5 of 13 Old 01-25-2016, 10:59 AM
Likes (Received): 23
I started using my Hydro Pro 32 for the 1st time on Saturday, started up the snowblower after I took a break and heard a loud popping sound and small flames shooting out from the hole. What caused the loud popping sound and the flames to shoot out from the hole?
SmokinBuddha is offline
post #6 of 13 Old 01-25-2016, 11:10 AM
Likes (Received): 280
When they are shooting sparks and popping they are running lean - you need to stop the machine and look at the carb. Don't let it run hot like that for very long......
Either you have a dirty carb or it's not adjusted right (if it's adjustable - some are not)
Thanks SmokinBuddha thanked for this post
post #7 of 13 Old 01-25-2016, 12:52 PM
Thanks (Given): 172
Thanks (Received): 337
Likes (Given): 476
Likes (Received): 836
I thought a few things could result in backfiring out of the muffler? Including an exhaust valve not closing fully, and maybe something like the spark plug not firing properly, letting a dose of raw, unburned fuel suddenly hit the hot muffler, which ignites it.
I have gotten backfires on my L-head Tecumseh when I'd suddenly reduce the throttle to idle, but I'm not sure of the exact cause in that case.
post #8 of 13 Old 01-25-2016, 01:27 PM
Likes (Given): 21
Likes (Received): 25
When you start the snowblower after it's warm put the choke on and it won't pop,these new engines are run lean.
2018 Ariens 938025 Professional 21 inch
2018 Ariens 921050 Platinum 369cc SHO 24"
2011 John Deere X728/47" Quick Hitch Snowblower
Life is too short to sweat the petty stuff
vmaxed is offline
post #9 of 13 Old 02-06-2016, 07:22 AM Thread Starter
Well I switched back to premium gas, and popping went away. Running perfect again.
Jim L.I. is offline
Thanks knu2xs thanked for this post
post #10 of 13 Old 02-06-2016, 06:14 PM
Likes (Received): 13
There are no adjustments on many of these carbs except idle. I had a 4 year old Deluxe 28 with the Briggs that would backfire every time I would turn the throttle down to idle. I called a very reputable local Ariens dealer and he said it is due to the manufacturers leaning them out for emissions and there is basically nothing they can do. Took off the carb and cleaned the entire thing and put back together and same thing. I know this is not your exact problem, but just giving you a heads up if you are thinking carb adjustments-there probably aren't any. I would also have blue flames coming out the muffler when it had to work pretty hard(not good). Maybe check to see if it is tightly fastened to intake so it is not sucking air. The good news is you can get a replacement carb for these fairly cheap off ebay or Amazon if you wanted to try a different one.
Toro 1128 HD PowerMax, 342cc, 16.5 ftlbs, 11+ HP
Ariens 722, 7HP single stage
hfjeff is offline
