Disc-O-Matic Drive -VS- Hydrostatic Drive - Snowblower Forum : Snow Blower Forums
post #1 of 39 Old 01-25-2016, 09:26 AM Thread Starter
Looking at the Ariens website I see their professional models have a choice of two drives.
Anyone have any experience with both and can comment their opinion the two?
trx680 is offline
post #2 of 39 Old 01-25-2016, 09:51 AM
Thanks (Given): 588
Thanks (Received): 769
Likes (Given): 4353
Likes (Received): 1736
If I was going new I'd get a hydro. Used I'm a little leary of them simply because of cost to repair.
The disc drive is very old technology but the reason it's still the common system is cost and ease of maintenance and repair.
Some other peoples opinions: The "Friction Wheel" versus The Hydrostatic Transmission drive debate
post #3 of 39 Old 01-25-2016, 10:02 AM
Thanks (Given): 173
Likes (Given): 453
Likes (Received): 1029
I've not had any experience with hydro units but for the extreme low cost and the proven effeciency of the disc drives I'll hang with them. In over 20 years of moving snow I've never experienced any problems with them. JMHO
post #4 of 39 Old 01-25-2016, 10:42 AM
Likes (Given): 48
Likes (Received): 74
The disc drive on my 1973 Ariens still pulls hard and works flawlessly! Proven technology and cheap to repair.
Cub Cadet 2X 524 SWE
caddydaddy is offline
Likes 43128 liked this post
post #5 of 39 Old 01-25-2016, 11:19 AM
Thanks (Given): 173
Likes (Given): 453
Amen Brother!
post #6 of 39 Old 01-25-2016, 11:33 AM
Likes (Given): 1880
Likes (Received): 661
and simple to make
Likes micah68kj liked this post
post #7 of 39 Old 01-25-2016, 11:39 AM
E350's Avatar
Thanks (Given): 280
Thanks (Received): 62
Likes (Given): 159
Likes (Received): 77
I am one of the newest members of this forum and have only this season's (rather heavy) use of snow blowers. So take what I have to say with the understanding of my relative lack of experience. That said:
I have an Ariens ST1032 wheeled snow blower with a disc transmission. And a Honda HS1132TA tracked snow blower with hydrostatic transmission.
Initially, I hated the Ariens' disc transimssion because I didn't like how it moved or wouldn't move under its own power. Especially in reverse. (I called it "pull assist" instead of "reverse").
I then bought the Honda hydrostatic because it is tracked and tracked is much better than wheels for my particular sloped dirt driveway, recreational residence when I can't get on it the next day after snowfall, application.
The Honda hydrostatic works flawlessly, it is infinitely variable in forward speed. But realisticly I only use two forward speeds - either full speed (where I am doing laps - an electric chute rotator would be great then) or crawl (when I am obsessively compulsively scraping set up slush). (California only rarely has what Easterners call "ice.") Theoretically, the Honda is also likely infinitely variable speed in reverse, but realistically I only use full speed reverse - which is slow enough.
I then replaced the friction disc in the Ariens with one of those ~$13/free shipping Ariens OEM discs on ebay and adjusted the disc engagement/drive tension bolt. A very, very, very easy task to do. (If you watch a couple of youtube videos with coffee first.)
WOW !!! What a difference that made on the Ariens! True reverse and however many forward speeds, all working flawlessly.
Conclusion: The only practical thing that the Honda hydrostatic transmission has that is missing from the Ariens disc transmission is possibly the barely moving forward "crawl" speed. And that the Honda can be moved into a faster forward speed without stopping. The Ariens disc transmission needs the snow blower not to be moving before "shifting" into a higher forward gear. Bottom line, is that I would have no problem with either type of transmission. And replacing a disc and adjusting its drive tension is easy peasy.
It is my understanding that, at least the older, Yamaha tracked snow blowers are disc driven. Compared to the Honda tracked snow blowers which are hydrostatic.
On garden tractors I have a definite preference for hydrostatic drive and am in the process of becoming a "hydrostatic fanatic." Hopefully, I will never need to repair the Honda HS1132TA snow blower's hydrostatic transmission, but if I do I should have some knowledge about how to repair it by virtue of my now accumulating hydrostatic transmission experience with the garden tractors.
It just occurs to me that I should add this post to my Honda HS1132 vs. Ariens ST1032 comparison thread...
E350 is offline
Post Thanks / Like - 4 Thanks, 3 Likes, 0 Dislikes
Thanks Loco-diablo, detdrbuzzard, RedOctobyr, Niraj KP thanked for this post
Likes Loco-diablo, RedOctobyr, Niraj KP liked this post
post #8 of 39 Old 01-25-2016, 11:49 AM
Thanks (Given): 173
Likes (Given): 453
Very well written and concise, objective evaluation from someone who has experienced both systems. Thanks, E350.
post #9 of 39 Old 01-25-2016, 02:19 PM
Thanks (Given): 14
Thanks (Received): 17
Likes (Given): 36
Likes (Received): 31
I've owned 2 Ariens disco's over the past 25 years. I've never had a disco related drive problem on either machine. If kept in good order by replacing the disc every so often and making sure the adjustment is proper, this is a good drive system IMO.
That and the fact I'm to cheap to spend $2500 on a snow blower!
I could buy 2 new disco's for the price of 1 new hydro. like i said, I'm cheap!
250cc B&S (1150 ft lbs)
Loco-diablo is offline
post #10 of 39 Old 01-25-2016, 11:28 PM
I own a hydrostatic snowblower. I had oil leaking from the hydrostatic transmission box.
I could successfully replace the seal lips that leak, add oil and purge.
However, it was not a very easy job... I'm a handy man.
Taking out the transmission itself was a hassle especially I couldn't find any online videos or any instructions to show how to take it out.
Also the snowblower manual has no information about the transmission.
So when repairing the transmission, you have to find the manufacturer and your model number of the transmission and start searching on the internet the parts manual, and the maintenance manual and your nearest dealer to buy parts.
From what I see, friction disc is easy to repair DIY, and you buy your parts from your snowblower parts manual
Operational: Hydrostatic is better, you have infinite of speeds between zero and the max speed.
Sometimes I need a very low speed which cannot be found with the friction disc.
Also you can change speeds and change forward and reverse without disengaging
goal80 is offline
