Walk This Way - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 01-25-2016, 07:09 PM Thread Starter
Walk This Way
I have a 28" Deluxe, model 921022, that is about three seasons old. I'm in NYC, so my season probably means about as much use as some of you guys get in a week, hahaha.
The machine has started veering to the left. For example I select a medium forward speed and I attempt to walk down the sidewalk, it will turn to the left and be off the sidewalk in about 8 feet.
This problem started late last year and I found a severe tire pressure mismatch. I correct this and the problem still happens, but not as badly.
Where should I start looking to find the problem?
PS: I'm glad I found this forum, I wished I knew about you guys a couple of years ago!
OsoRojo is offline
post #2 of 13 Old 01-25-2016, 07:12 PM
Thanks (Given): 11
Thanks (Received): 111
Likes (Given): 19
Likes (Received): 311
Are the scraper bar and skids on the auger housing adjusted correctly, and not worn out?
A problem with either/both of those items could cause one side to drag more than the other and make the machine want to turn.
ELaw is offline
post #3 of 13 Old 01-25-2016, 08:01 PM
Thanks (Received): 123
Likes (Given): 43
Likes (Received): 889
https://www.youtube.com/watch?v=pL4u...?v=pL4uESRCnv8
Coby7 is online now
post #4 of 13 Old 01-25-2016, 09:58 PM Thread Starter
I will check them out. I've see how to adjust the skids, is there a reference on how to adjust the scraper bar?
OsoRojo is offline
post #5 of 13 Old 01-25-2016, 10:00 PM
Thanks (Given): 590
Likes (Given): 4371
Likes (Received): 1743
to the forum OsoRojo
https://www.google.com/url?sa=t&rct=...12454388,d.amc
post #6 of 13 Old 01-25-2016, 10:39 PM
Thanks (Received): 143
Likes (Received): 297
Might want to use a couple of paint sticks, instead of the eyeball method that the video uses.
post #7 of 13 Old 01-25-2016, 10:57 PM
Thanks (Received): 87
Likes (Given): 57
Likes (Received): 269
sheesh, what did they do to that poor ST? Blue all over the place
GoBlowSnow is offline
post #8 of 13 Old 01-25-2016, 11:22 PM
Looks like it ingested a paint can.
post #9 of 13 Old 01-26-2016, 10:25 AM
Thanks (Given): 34
Likes (Given): 58
Likes (Received): 33
May be a silly question but you never know.
Any chance you broke a shear pin and only one auger is spinning?
1999 Ariens 924108 824SLE.
1933 GE Monitor Top refrigerator restoration video
ChrisJ is offline
post #10 of 13 Old 01-26-2016, 11:02 AM
Thanks (Given): 66
Likes (Given): 114
Likes (Received): 157
Sounds like you have:
1. excessive resistance in the left side skid shoes or scraper bar poorly adjusted so you can check those settings as others have said.
2. Tire size is different left to right; tire size would be shown on sidewall such as 4.80 x 8 or you could measure the circumference by marking a point on tire and pavement (both tires) and move machine forward to the point where the mark meets the pavement again and mark the pavement; measure the distance between the marks on pavement for each tire and they should be the same, but for machine to veer left the right tire would have a longer distance between its marks.
3. There may be a problem with the trans which is slowing left wheel so you can try holding back machine with engine running and driving forward in second gear to see if both wheels spin or pull you forward as they should, or if drive is on right wheel predominantly. If right wheel spins and not left then the trans needs to be investigated further.
You can check your purchase date against the warranty period and you may be covered. Much easier to get the problem resolved by a dealer usually.
Good luck.
Town is online now
