Cannot operate blower one handed - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 01-26-2016, 10:30 AM Thread Starter
Thanks (Given): 34
Likes (Given): 58
Likes (Received): 33
The locking mechanism on my machine barely worked the day I got it (used and abused) and doesn't work at all now. From what I recall, the auger control should stay down as long as I hold down the drive lever? No such luck on my machine.
It seems way too simple, but is there any chance this is the only part I need to replace?
It looks like the edge on mine is rounded and is stopping it from locking but I'm hoping, maybe, this is both a very old and common setup and perhaps this is a very common problem.
With my luck, Ariens only used this setup for one year.
ID:	75313   Click image for larger version
1999 Ariens 924108 824SLE.
1933 GE Monitor Top refrigerator restoration video
ChrisJ is offline
post #2 of 11 Old 01-26-2016, 11:24 AM
Thanks (Given): 173
Likes (Given): 453
Likes (Received): 1029
and model/size would be helpful. All snowblowers are not created equal.
Is there some way of filing it deeper so it'll hold? I've had to do that on my old wheelhorse tractor levers.
Thanks ChrisJ thanked for this post
post #3 of 11 Old 01-26-2016, 11:28 AM Thread Starter
Thanks (Given): 34
Likes (Given): 58
Is there some way of filing it deeper so it'll hold? I've had to do that on mynold wheelhorse tractor levers.
Sorry, it's in my signature.
I had considered filing / grinding it but haven't had a chance to look at it.
ChrisJ is offline
post #4 of 11 Old 01-26-2016, 12:21 PM
Thanks (Given): 173
Likes (Given): 453
Shoot. I rarely look at the sigs. Since it's not under warranty what have you got to lose by filing it a bit? Don't go too far. If you get it to work stop there. You don't want to go too far. There's a reason for it to unlock when the handle is released.
SAFETY FIRST
Likes ChrisJ liked this post
post #5 of 11 Old 01-26-2016, 12:54 PM
Thanks (Given): 172
Thanks (Received): 335
Likes (Given): 475
Likes (Received): 834
I have year 2000 Ariens 1024 Pro. Probably the same setup as your '99, or at least very close.
I bought mine used, and my lock wouldn't stay engaged either. I did what you're describing. As I recall, I removed the piece, and found that the area that should be "vertical" had kind worn into more of a ramp. I believe it's the area shown in the middle of your picture, that's where the lock is supposed to engage.
I used a file and tried to make it more of a vertical wall again, rather than kind of rounded and angled. It needs to be a sharp inside corner, and a "vertical" wall, to work properly, in my opinion. If that vertical surface turns into more of a ramp, it will want to unlock itself.
Filing it helped, but it would still sometimes release. I then added another spring, to increase the tension holding this arm against the mating piece. After adding the additional spring, it worked reliably last season.
I considered welding this piece up, then re-grinding it, but I haven't had to resort to that yet. Either this piece, or the mating one, was rather expensive as I recall. Maybe it was the mating piece that was expensive, but I figured it was worth trying to fix, vs just replacing the parts.
I had a '93 Ariens that never had this trouble. So maybe they changed the design, or perhaps they had some issues with the parts around '99-2000?
post #6 of 11 Old 01-28-2016, 08:57 AM
Thanks (Given): 173
Likes (Given): 453
ChrisJ..,,Did you get this problem taken care of?
post #7 of 11 Old 01-28-2016, 09:02 AM Thread Starter
Thanks (Given): 34
Likes (Given): 58
Hi,
No, haven't had time. Unfortunately I work very long hours and don't get home until late at night so I won't be working on it at all until this weekend.
ChrisJ is offline
post #8 of 11 Old 01-28-2016, 12:44 PM
Thanks (Given): 173
Likes (Given): 453
I'm curious how this'll turn out. Let us know what happens.
post #9 of 11 Old 01-28-2016, 01:09 PM Thread Starter
Thanks (Given): 34
Likes (Given): 58
Will do.
ChrisJ is offline
post #10 of 11 Old 02-14-2016, 09:50 AM
Reg
Don't know if someone else mentioned this but I had the same problem with my 1994 ST1032 (couldn't operate it one-handed). I replaced the spring that keeps the long control arm engaged and that solved the problem. No doubt the original spring had lost some tension.
Reg is offline
