Lubeing Ariens Deluxe 28 Drive System - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 01-26-2016, 03:53 PM Thread Starter
Likes (Given): 7
What type of grease should I use? I have white lithium in a spray can or Mobil one synthetic in a grease gun I can use. Does it matter what kind I use?
Or should I just leave whatever is on there. It appear to have lots of grease left on it.
ICECOLDBEER is offline
post #2 of 12 Old 01-26-2016, 03:55 PM Thread Starter
Likes (Given): 7
I'm still kind of confused where I need to put the oil and grease.
It looks like whoever grease it before used some sort of green grease. Should I try to find some green stuff?
post #3 of 12 Old 01-26-2016, 03:57 PM Thread Starter
Likes (Given): 7
Is the rust on these parts concerning? And would you recommend I put anything on them to keen the rust in check? Fluid film?
ID:	75393   Click image for larger version
post #4 of 12 Old 01-26-2016, 03:59 PM Thread Starter
Likes (Given): 7
Last question. This is from the axle. That piece of metal sits in a slot and lined up with a grove on the tire. Is it supposed to come off? The one on the opposite axle seems firmly in place.
post #5 of 12 Old 01-26-2016, 04:00 PM
Any kind of grease really. Something for low temperatures would be ideal so it doesn't gum up when it gets cold. Definitely don't put anything on the belt pulley though. The rest of those parts could use a light coat to prevent rust. You never want to grease belts, pulleys or friction disc plates though.
A lot of machines use different types of keys to hold parts from spinning on shafts. It is normal for them to fall out when the pieces are taken apart. They just sit in grooves.
Thanks ICECOLDBEER thanked for this post
Likes ICECOLDBEER liked this post
post #6 of 12 Old 01-26-2016, 04:08 PM Thread Starter
Likes (Given): 7
Okay I guess I am really over thinking the whole grease thing but I want the machine to last.. The mobil one says high temp grease not so sure about low temps.
post #7 of 12 Old 01-26-2016, 04:37 PM
Yea, the issue with grease is when it gets cold it turns to a thick paste. That is bad for the shifter because it will gum up and make it difficult to shift gears. The good news is even if you mess something up you can just wash if off and start over.
post #8 of 12 Old 01-26-2016, 05:00 PM Thread Starter
Likes (Given): 7
Yeah I just did it now. Used the mobil one and started her up. She ran just fine. How much grease is ideal? Does it need to be coated or just very light? I just coated it and then spun the axles and wiped off any excess. None got on the friction plate.
post #9 of 12 Old 01-26-2016, 05:12 PM
It has to be a pretty light coat. If you get too much on there it will sling around when things start spinning.
post #10 of 12 Old 01-27-2016, 12:06 AM
Thanks (Received): 87
Likes (Given): 57
Likes (Received): 269
Mobil-1 grease is what i use, it does just fine in the cold. It is a synthetic grease. As for the light surface rust, I would not be too worried about it. Keep an eye on it over the years.
GoBlowSnow is offline
