Need help with my 73 - Snowblower Forum : Snow Blower Forums
post #1 of 36 Old 12-18-2013, 02:18 PM Thread Starter
First sorry so long... I have a 73 32" cut that all of a sudden doesn't want to move any more. It was working just fine, then all of a sudden it wouldn't move, no noises nothing. Took bottom plate off all looks good in there, if I lift the wheels off the ground they turn, but I can grab a wheel with my hand and it stops. It looks to be a broken shear pin on the L axle behind the wheel and on the outside of the body. There is a hole in the axle but I cant seem to find a corresponding hole in the center shaft ( if that makes sense). When it is off the ground and I stop the wheels by hand the friction disk keeps spinning but axle does not. What could this be, and if a shear pin where is it? Thanks Larry
minitrk is offline
post #2 of 36 Old 12-18-2013, 02:26 PM
Thanks (Received): 28
Likes (Received): 58
depending on the model. the friction wheel and shaft it is on is connected to the axle by a chain and 2 sprockets. or 2 gears that mesh with no chain.
If the friction wheel and the shaft it is on is spinning check the 2 gears or the 2 sprockets. each one will be kept in place on the shafts (one on the friction wheel shaft and one on the axle) by a keyway and set screw or a bolt.
you said when you hold the tire the friction keeps going but the axle stops. Do the tires spin on the axle with out the axle spinning?
td5771 is offline
post #3 of 36 Old 12-18-2013, 02:32 PM Thread Starter
I have the chain and 2 gears, when I grab the tire EVERYTHING - friction disk, chain and both gears still spins but not the wheels/axle. It looks like there is a bearing in the gear the axle goes through??? I will get pics if needed
minitrk is offline
post #4 of 36 Old 12-18-2013, 02:42 PM
pic would be great. model number. example...924xxx 922xxx 910xxx
the connection between the gear and axle is gone. either a keyway has sheared ir something else depending on the model.
td5771 is offline
post #5 of 36 Old 12-18-2013, 02:56 PM Thread Starter
OK got pics... no idea on model # that part of sticker is gone. So 1st pic may help ID it, In 2nd pic you can see hole in axle I was referring to, and 3rd pic you can see what I was referring to about bearings in the gear?? but why would it be splined? Anyway does better than all the new ones in the neighbor hood (besides the Hondas) when it moves...
minitrk is offline
post #6 of 36 Old 12-18-2013, 03:12 PM
Likes (Received): 11
Looks like your model uses 2 levers, one to engae the auger and the other to engage the drive. In the first picture I can see the auger lever but I can't tell if the drive lever is hidden by the motor or missing all together
HJames is offline
post #7 of 36 Old 12-18-2013, 03:17 PM Thread Starter
yes 2 levers one auger one drive
minitrk is offline
post #8 of 36 Old 12-18-2013, 03:23 PM
Can you feel spring tension when you engage the drive lever. On mine if the drive lever is not engaged and I lift the blower by the bars the wheels will spin but not with any power, could be that you don't have enough tension on the belt
HJames is offline
post #9 of 36 Old 12-18-2013, 03:42 PM Thread Starter
yes everything is the same, I was using it when it happened. There was no noises like something broke or anything. It just stopped moving.
minitrk is offline
post #10 of 36 Old 12-18-2013, 03:59 PM
In your last pic. The big gear on the axle. There is a keyway between the axle and the gear. If that gear spins independently of the axle that is the problem. The key has broken/sheared. It would not have made much/any noise.
I believe on the side of the gear there are screws/bolts. The gear is sandwiched between. The two plates. Remove the plates and you will be able to see the center of the gear and the key.
Ensure that the gear is spinning free on the axle.
td5771 is offline
