Traction Drive Belt Question - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 01-28-2016, 09:06 AM Thread Starter
Hi Guys-
Is the Traction Drive Belt supposed to spin whenever the engine is running or only when the Drive Clutch is engaged? My Traction Drive Belt starts spinning as soon and I start the engine, but the blower stays stationary until I engage the Drive Clutch.
Thanks,
Scott
setrusko is offline
post #2 of 5 Old 01-28-2016, 10:34 AM
Likes (Received): 280
Hi Scott - yeah most machines the belt just gets tensioned by the cable when you pull the lever and it's a tighter fit around the pulley. The belt my still spin some when you let the tension off but not enough to move the machine...... you can adjust the tension amount on them as needed. When the wheels seem to have less power you tighten it up a bit.......
post #3 of 5 Old 01-28-2016, 10:43 AM
Likes (Received): 42
Many engines have a tightly fitting drive (inside) pulley that rotates at driveshaft speed. When you engage the fiction drive, the rubber "tire" engages the drive disc to give you movement. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
8 hp MTD hybrid plow
motorhead64 is offline
post #4 of 5 Old 01-28-2016, 12:32 PM
Yes, Normally the traction belt is always engaged.
post #5 of 5 Old 01-28-2016, 02:12 PM
Thanks (Received): 112
Likes (Received): 298
Originally Posted by setrusko View Post
Hi Guys-
Thanks,
Scott
Depends on the machine you have.
I had an 1983 Craftsman 8/25, and the traction belt worked the same as the auger belt, it was slack until the clutch pulled in an idler wheel, ant things started to move.
My 2008 machine has the traction belt spinning all the time, and the clutch moves the drive plate into the friction wheel when actuated.
Work fascinates me.
skutflut is offline
