lit up my 921018 with LED's - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 01-29-2016, 10:36 PM Thread Starter
well like everyone else I want to see what I'm doing in the dark, so between the hand warmers and the stock light I decided to increase my stator to ten amps, that gave me 120 watts to play with, following the LED thread I added the needed AC/DC electronics, I changed the stock bulb to a 11 watt led then put 2 18 watt led's on the bucket. Not in the picture I added 2 10 watt led's on the lower handle bars rolled out to light up the sides. I'll add an updated picture soon. I'm happy how it turned out
11+18+18+10+10=67 watts light
40 watt hand warmers+67=107 watts
120-107=13 watts leftover
ID:	76193   Click image for larger version
ID:	76201   Click image for larger version
putty is offline
Likes nycredneck, Clearview60 liked this post
post #2 of 15 Old 01-29-2016, 10:48 PM
Likes (Received): 280
Nice - but you left 13 watts! :>) Maybe a little rear light ..
post #3 of 15 Old 01-30-2016, 08:15 AM
Thanks (Given): 590
Likes (Given): 4367
Likes (Received): 1742
I'm convinced it was intentional, it's for the coco warmer
Nice job on the installation. That must be crazy brigh
Likes LET-UT liked this post
post #4 of 15 Old 01-30-2016, 09:53 AM
Thanks (Given): 172
Thanks (Received): 338
Likes (Given): 477
Likes (Received): 837
That's awesome, nice work!
post #5 of 15 Old 01-30-2016, 09:32 PM
That is SWEET !!!
Ariens ST11528LE, 924125
Craftsman 536.884800, 5/23
Toro CCR-Powerlite 38182
nycredneck is offline
post #6 of 15 Old 01-30-2016, 09:45 PM
Thanks (Given): 590
Likes (Given): 4367
And soon the new machines will have as many cup holders as a Chrysler minivan !!
Likes bad69cat liked this post
post #7 of 15 Old 01-31-2016, 10:08 AM
Thanks (Given): 34
Likes (Given): 58
Likes (Received): 33
What LED lamps are those?
1999 Ariens 924108 824SLE.
1933 GE Monitor Top refrigerator restoration video
ChrisJ is offline
post #8 of 15 Old 01-31-2016, 11:15 AM Thread Starter
There 18 watt Cree LED's, again I stuck them on the top of some 3/4 tubing to lift them off the bucket a little
Name:	18 watt cree LED's.jpg
putty is offline
post #9 of 15 Old 01-31-2016, 12:00 PM
Thanks (Received): 112
Likes (Received): 298
Which Briggs engine model do you have on that machine. Also, do you happen to know the part number of the flywheel, and the original stator you had on there?
I have been digging a bit to find an higher output stator for my engine, and I think there are options, but the Briggs Alternator chart is pretty outdated as to model numbers and what fits what.
I am curious if your flywheel has the same part number as mine, which would answer several questions.
Mine has a 794812 flywheel with small magnets.
Work fascinates me.
skutflut is online now
post #10 of 15 Old 01-31-2016, 03:51 PM Thread Starter
it took a lot of research then a guess, my engine is 21M314-0121-E1, I think 797090 5 amp ac Alternator was original, my notes say I have the same flywheel. I basically used the engine parts sheets and the b&s alternator ID chart and matched the engine series-210000. Also note the new alternator has 4 screw holes and b&s only tapped the 2 needed for the original, so you got to tap the other 2 posts.
putty is offline
