Ariens recoil start - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 02-01-2016, 10:37 AM Thread Starter
Ariens recoil start
First technical post. I searched the forum the best I could but didn't see anything. I picked up a ariens st724 model number 932022. The recoil starter is broken, seems to have broke the arm/part that connects to the cup. I've searched the Internet and can't seem to find a replacement. This one has a hole through the center that a shaft goes through to turn a generator, that mounts on the back side of the starter, to power the light. Has anyone encountered this before? Any ideas where to get one?
ID:	76817   Click image for larger version
ID:	76833   Click image for larger version
Gipp83 is offline
post #2 of 6 Old 02-01-2016, 10:56 AM
Thanks (Given): 587
Thanks (Received): 765
Likes (Given): 4339
Likes (Received): 1727
It might be more helpful if you gave us the numbers off the engine
Is it a Tecumseh H70-130266L ??
http://www.searspartsdirect.com/mode...400/00001.html
http://www.ebay.com/itm/New-Genuine-...-/361479550202
http://www.repairclinic.com/Shop-For...-Starter-Parts
I would want to make sure it's the same engine before ordering anything but it seems the assembly might still be available from some sources or the parts for that pawl if it's repairable.
Likes ProParts liked this post
post #3 of 6 Old 02-01-2016, 11:05 AM
ProParts's Avatar
Likes (Received): 8
Gipp - bit more info for you in link below. It explains what info you need to get from the engine. Best bet is to snap a pic when you find the numbers.
Tecumseh Parts Diagrams - ProPartsDirect
Mow - Snow 24/7.
ProParts is offline
post #4 of 6 Old 02-01-2016, 11:48 AM
if i were you i would cut that pin off and use the starter listed below. if you need one i have tons of used ones
post #5 of 6 Old 02-01-2016, 08:58 PM Thread Starter
Sorry should of included that. Yes, it's a H70-130266L. I've searched most of the repair sites, and either their not setup for the generator or not available anymore. I'll probably end up eliminating the light if it comes down to it. 43128 I would be interested in one if i can't find that exact one.
Gipp83 is offline
post #6 of 6 Old 02-03-2017, 06:20 PM
orangputeh's Avatar
Thanks (Given): 762
Thanks (Received): 234
Likes (Given): 1577
Likes (Received): 1650
Robot Check
would this starter work on an ariens 1028?
or do you have one that would work for mine? you can PM me. Thanks.
"It Feels Like Beer O'Clock "
orangputeh is online now
