Anyone with Briggs 342cc and heated handgrips and light? - Snowblower Forum : Snow Blower Forums
post #1 of 21 Old 02-01-2016, 01:16 PM Thread Starter
Likes (Received): 13
Looking for the engine model number and type. I have a Toro 1128 that came with factory light and I added heated grips. I had to change the alternator but the light still dims a little. So not sure my dealer sold me the correct alt. If you have this combination in a Ariens (Heated grips and light with Briggs 342cc) could I get the engine model from you and type? it should be stamped on the side of the valve cover. Thanks.
hfjeff is offline
post #2 of 21 Old 02-01-2016, 01:50 PM
Likes (Received): 10
On my old 342cc Briggs I had on my "Husky" I remember the light dimming when I turned the handwarmers on.
JRHAWK9 is offline
post #3 of 21 Old 02-01-2016, 03:20 PM
Thanks (Given): 102
Likes (Given): 273
Jeff, I've got an Ariens 921036 which is B&S 342cc + heated grips. No dimming noted with the use of heated grips.
uberT is offline
post #4 of 21 Old 02-01-2016, 03:47 PM
Thanks (Given): 102
Likes (Given): 273
Diagram: 474G
Part number: 797090 Alternator
Used on Type No(s).
0110, 0113, 0114,
0117, 0121, 0134,
0135, 0137, 1470,
1475, 1476, 1478,
1481, 1483, 1600,
2121, 2470, 2476,
2481, 2483, 3475
uberT is offline
post #5 of 21 Old 02-01-2016, 06:30 PM Thread Starter
Thank you sir! My dealer sold me 696742 which is a dual circuit (did not need AC). It is only rated for 2-4 amps DC. I am thinking my light should not dim if I had the correct alt. I had an Ariens Deluxe 28 that I added the Ariens heated grip kit and the light did not diim while running the heated grips. You are running the same alt that my Ariens 250cc had. I will research and see if this will work with my flywheel. Do you know what flywheel you have? Thanks.
hfjeff is offline
post #6 of 21 Old 02-01-2016, 07:56 PM
Thanks (Given): 102
Likes (Given): 273
No, I don't know anything about the flywheel. I do have the parts manual if you want me to send a copy to you. I tried to upload it but it exceeds the size limitation.
uberT is offline
post #7 of 21 Old 02-01-2016, 07:58 PM
Thanks (Received): 112
Likes (Received): 298
If that light is halogen you could run it off the AC output, and leave the
DC for the grips. Or stick a full wave bridge rectifier and a couple of capacitors on the AC output and turn it into DC if you have LED lighting
Work fascinates me.
skutflut is offline
post #8 of 21 Old 02-01-2016, 09:16 PM
I have a Briggs and Stratton 21M314-0121-E1 with a 797090 5 amp Alternator that I pulled out for a 10 amp one, I got a 794812 Flywheel
putty is offline
post #9 of 21 Old 02-01-2016, 10:50 PM Thread Starter
I found a brand new 797090 on Ebay for $15 plus free shipping so I snagged it. I will give it a try. Interesting info about using the AC if it is a halogen bulb. I am not sure if it is or not but worth checking. Here is what was in it and what I replaced it with:
I cut the DC lead off the original and spliced it on the new alternator so I could keep the same harness connector. I taped off the AC lead. On the old one, black was DC. On the new one Red is DC and Black is AC. They both have the same diode part number built into the lead as shown in the pics.
hfjeff is offline
post #10 of 21 Old 02-02-2016, 04:12 AM
I wonder if you could cut off the diodes and feed both lines to a ac/dc rectifier(like from the LED thread). Seems like the one your not going to use would have more amps. More amps you could add some Led lighting.
putty is offline
