First oil change AX414 cc with side drain - Snowblower Forum : Snow Blower Forums
post #1 of 31 Old 02-01-2016, 05:48 PM Thread Starter
Thanks (Given): 9
Likes (Received): 16
First 5 hours (not many storms so far), drained oil and added 38 oz. of 5-30 synthetic. Made this simple trough to save having to remove the wheel. Worked perfectly. Used a piece of aluminum left over from trim on house, bent it one side higher so oil will not spill.
ID:	77017   Click image for larger version
2015 Ariens 28+ 414cc, drift cutters, poly skids, Ariens Cab. Debating about hand warmers.
2001 Yardworks 30/10.5 hp (sold)
1991 Yardman 24/5 hp (gave to son)
Large snow pusher for wife.
Bob z is offline
Likes shallowwatersailor, 69ariens liked this post
post #2 of 31 Old 02-01-2016, 06:18 PM
Likes (Received): 7
I use an old license plate. I put a large key ring in the top hole. I slip that ring over the drain extension off the motor. Slide/trough quits slipping off to create a mess.
Mr Fixit is offline
post #3 of 31 Old 02-01-2016, 06:38 PM
Thanks (Given): 82
Thanks (Received): 173
Likes (Given): 424
Likes (Received): 666
just did the first oil change on my old repowered ariens, no extension tube on it, but did something "kinda" like you did Bob. on the chonda, there is just enough room under the block to slip a piece of thick paper ( cut from a dog treat box). slid a tab under the block, folded up the sides to make a trough, blocked the machine up so it was well tilted to the right, and basically no spill ! well just a few drops when i removed my disposable trough.
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
nwcove is offline
post #4 of 31 Old 02-01-2016, 11:03 PM
I bought one of these and it has worked out pretty well.
FORM-A-FUNNEL | Oil Change Funnel | Auto Repair Oil changing kits
setrusko is offline
post #5 of 31 Old 02-02-2016, 06:02 AM
Likes (Received): 1384
DRAIN-ZIT has an App 4 that.
post #6 of 31 Old 02-02-2016, 07:55 AM
No Drain Plug/Drain Pipe to the rear, so that you could just tilt the Blower back on its wheels ?
Like on a Tecumseh with a 6" Drain Pipe ?
Vermont007 is offline
post #7 of 31 Old 02-02-2016, 08:18 AM
Thanks (Given): 592
Thanks (Received): 773
Likes (Given): 4377
Likes (Received): 1744
I just slit a 2 liter pop bottle the long way and use that. Wipe it down and store it with the drain pan and use it over and over.
post #8 of 31 Old 02-02-2016, 08:37 AM
Likes (Received): 12
I got one of these to clear the sway bar on my car when doing an oil change.....have used it for many other applications, including changing oil on my tractor and snowblower.
Very handy!
chrisexv6 is offline
post #9 of 31 Old 02-03-2016, 07:46 PM
Thanks (Received): 87
Likes (Given): 57
Likes (Received): 269
I use a piece of old plastic sprinkler tubing. runs right into my oil collection basin. very little mess.
GoBlowSnow is offline
post #10 of 31 Old 02-03-2016, 08:17 PM
Likes (Received): 62
Cut the side out of an empty motor oil plastic bottle and use it as a funnel. If you have a tight area, cut out the narrow side. Or cut out the wide side and have a larger area to catch the stream. Plus you have the spout for the oil to flow into another container. Can't be the cost for this one.
CO Snow is online now
