1970 ariens carb bowl question - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 02-05-2016, 07:10 PM Thread Starter
Thanks (Given): 10
Before i get really upset and weld this stupid thing shut i want to ask you knowledgeable folks what the best way to fix this carb bowl might be. This is the first carb i have seen that has a quick bowl drain spring loaded pin thingy in it. probably is the gasket material is all dried out and that pin is small. I have tried a very small oring on it with some success. It still leaks a little. I have tried making my own gasket out of a new eng thermostat gasket which leaked like a sive..lol..i am not sure what else to try that is safe with gas and wont break down or leak..I am very close to welding the hole shut and ditching the quick drain pin idea..LOL
Toxic is offline
post #2 of 5 Old 02-05-2016, 07:26 PM
Likes (Received): 42
Hi Toxic
You are angry at the "bowl drain" which allows the owner to drain fuel from the bowl with the fuel shutoff "off" so that the bowl can be removed for cleaning. Newer machines were made without the drain, probably due to the leaking issue. You can replace the bowl with the newer version, or simply epoxy closed the drain hole. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
8 hp MTD hybrid plow
motorhead64 is offline
post #3 of 5 Old 02-06-2016, 01:17 AM
td5771's Avatar
Thanks (Received): 28
Likes (Received): 58
I have an envelope with a handful of NOS Tecumseh fuel bowl drain pin gaskets. I got them with a bulk Tecumseh parts lot I bought. PM me and I will get one to you.
td5771 is offline
Thanks Toxic thanked for this post
Likes dbert, Toxic, Grunt liked this post
post #4 of 5 Old 02-06-2016, 01:03 PM Thread Starter
Thanks (Given): 10
Fantastic!..Pm send..Huge thanks too!
Toxic is offline
post #5 of 5 Old 02-07-2016, 02:17 AM
td5771's Avatar
It is on its way.
For anyone that needs one they are still available.
Tecumseh part number 27554
td5771 is offline
Likes classiccat, Toxic, Grunt liked this post
