Ariens Will Not Shift Out Of High Gear - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 02-05-2016, 09:03 PM Thread Starter
Shifter will not move from highest gear. So no reverse either. Disconnected rod from shifter, Opened it up, no loose washers and on the forks as far as I could see. Tried tapping the friction wheel and is carrier lightly with wood block and rubber mallet after disengaging the connecting rod to the console /dash . Tried moving it by hand. Tried cussing. Even ignored it for a minute but its just jammed up in there.
Model 932-026 ST 524
SN 010189
About 25 years old? Runs great but stuck in high gear, real high. ( Outside edge of drive wheel is contact point of friction wheel). Only thing I can think of is i cannot see a stop tab on the friction wheel axis outside edge, maybe Friction wheel jumped it and is jammed on it? Don't want to go that far in dismantling the friction wheel dead winter here in UTAH, but I guess its that, the shop, or running w it. Literally!
Looks well greased up. Any ideas or should I just dismantle the whole thing? It's been snowing to beat the bands here--
mever is offline
post #2 of 4 Old 02-05-2016, 11:26 PM
Normex's Avatar
Likes (Received): 82
[QUOTE=mever;928585]
SN 010189
Hi Mever and welcome to the forum, normally there is supposed to have a small spring pin in the hex shaft that stop the friction wheel but I can't be certain on a 25 yr old model nevertheless you should try to feel for a small hole around the region where the friction disk would be close to the edge on the Hex shaft.
So you're saying it doesn't budge from that location as it must be slightly
beyond the edge of the friction wheel and you may be able to feel it as well. If so just take a flat screwdriver and try to pry on the friction wheel.
Other than that it would be nice to have a few pics.
Ok Good Luck
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
post #3 of 4 Old 02-06-2016, 01:08 AM
td5771's Avatar
Thanks (Received): 28
Likes (Received): 58
Like normex said, I am pretty confident it is just stuck. I have had to unstick at least 5 this year. Here is your friction drive parts breakdown--
Ariens 932026 (ST524) - Ariens 24 Snow Blower, 5hp Tecumseh (SN: 006000 - 012399) Friction Drive Diagram and Parts List | PartsTree.com
You have a tension pin on one end that may be broken off flush and none on the other end.
You just have to get in there without putting too much pressure on a breakable part.
td5771 is offline
post #4 of 4 Old 02-06-2016, 10:11 AM Thread Starter
Will try again-
I appreciate the responses. Its a rare warm day here going to give it another try and find if its stuck on the pin. It LOOKS like everything is ok in there , it is just jammed toward the outside. Let you know.
mever is offline
