Upgrading fuel tank on Platinum 30 SHO - Snowblower Forum : Snow Blower Forums
post #1 of 20 Old 02-06-2016, 10:05 AM Thread Starter
Thanks (Given): 66
Thanks (Received): 123
Likes (Given): 114
Likes (Received): 157
I cannot put more than 2.4 liters of gas in my 3 liter tank and it runs out of fuel several times while cleaning up after or during heavier snow falls. I would like to replace my fuel tank or somehow increase its size.
I was thinking of replacing my tank with the 1.45 gallon (5.5 liters) Ariens Pro gas tank.
Any ideas on how to go about increasing fuel capacity?
Town is online now
Likes knu2xs liked this post
post #2 of 20 Old 02-06-2016, 01:28 PM
I'm interested in this also, I usually have to fill up 2 times to do all the walks driveway etc. I get about 45 mins of run time out of a full tank.
Nickpsd is offline
post #3 of 20 Old 02-06-2016, 09:50 PM
Thanks (Given): 33
Thanks (Received): 37
Likes (Given): 64
Likes (Received): 87
Mine is a 414cc motor on a non-SHO Platinum 30 (921029) and my manual states 3.8 quarts US or 3.6 liters for both the 414cc and 291cc motor used in the Platinum 24 (921028) and Deluxe 30 (921032.)
How did you (Town) determine the actual capacity to be the 2.4 liters it really seems to be?
I really think Ariens should step up and give us bigger tanks, the size promised in all the literature of the time. How could they make such a big mistake?
2015 Ariens Deluxe 28+ 921037, 414cc LCT (now son's)
2014 Ariens Platinum 30 921029, 414cc LCT (mine forever)
PixMan is offline
post #4 of 20 Old 02-06-2016, 10:51 PM Thread Starter
Thanks (Given): 66
Likes (Given): 114
I have a plastic measuring container marked in liters and half liters. I put fuel into the container to the 2.5 liter mark and filled my empty tank. The fuel started to overflow before I was finished and the container still had 1 liter of fuel remaining. This was with the screen removed but the machine level. I have done this several times before and the volume depends on how much of an air gap you feel comfortable with. This last time it overflowed so is definitely overfilled and a bit less than 2.4 liters. Ariens sent a new tank to my dealer who measured it at 3 liters using 3 plastic oil cans filled with gas. The tank measurements were the same as mine. So I don't know how my measurements differ, but I trust mine.
Based on my experience I would not trust the Ariens 3.6 liters spec of your machine as accurate. The depth of my tank is 2.25" at the filler neck at point of overflowing. The bottom of the tank is flat and cannot go lower because of mounting point under tank and governor mechanism just below tank.
I figure I need a tank that is at least 5" tall and 9" wide and 10" long with an allowance for the oil fill. I intend checking the fuel tank dimensions for the Pro model which appears to be much taller and wider and longer with the oil tube allowance where it needs to be. But my fabrication skills are not a strength.
The other aspect is the engine is very powerful and very thirsty when it gets into deeper and heavier snow, it doesn't bog at all at a good walking pace. And it is only running at 3,500 rpm (in spec) but not up to 3,600 or 3,700 specs. So more power will probably mean more thirst. Another reason for a bigger tank.
Town is online now
post #5 of 20 Old 02-08-2016, 02:53 PM
Likes (Received): 18
Hopefully somebody figures something out...
Ariens 2015/2016 30" Platinum SHO #921040
88racing is offline
post #6 of 20 Old 02-08-2016, 04:03 PM
Likes (Given): 65
Likes (Received): 8
I'd give the good folks at Ariens a call and let them walk through the issue of tank size. If the tank is truly smaller than spec'd, they might have a replacement, or they may have a typo in the owner's manual. They'd be the ones who would most likely know if there's a larger tank that would fit your engine too. Good luck!
Proud owner of an Ariens "Turbine-Powered Drift-Crusher 4000" with optional flame powered auger heaters; aka Ariens Deluxe 28 921030
LET-UT is offline
post #7 of 20 Old 02-09-2016, 01:10 PM Thread Starter
Thanks (Given): 66
Likes (Given): 114
Yes I talked to my dealer and Ariens last year. The tank is what it is and way too small but no replacement. LCT list an optional 3.6 liter tank but not for my machine with the gen 3 414 engine. I believe it fits machines with the oil filler tube on the right side like the gen 2 LCT 414 engine, while mine has a left side oil filler tube. I thought with all the complaints last year that Ariens would up the spec for 2016 models, but it is the same small tank.
There is a rumour of a different engine for the Pro models for 2017 that came up as a reason for the very limited production of the 2016 Pro 32. If that turns out to be true and a LCT engine with the current sized 5.5 liter fuel tank it may fit earlier LCT engines. But that info will not be available until late August probably.
Town is online now
post #8 of 20 Old 02-09-2016, 09:32 PM
Thanks (Received): 127
Likes (Given): 79
Likes (Received): 172
Good thread with good posts, would be nice if Ariens offered to swap out gas tanks but I wouldn't hold my breath. The gas cap on these newer LCT GEN III engine is a design failure as well. The gas tank on the GEN II 414cc engine is definitely larger than the current lower profile design, how much larger I don't know. It also has a much better gas cap, my only issue with that motor was the side terminating oil drain tube next to the tire.
Cardo111 is offline
post #9 of 20 Old 02-20-2016, 06:01 PM Thread Starter
Thanks (Given): 66
Likes (Given): 114
The fuel tank has 4 mounting points, two at the side where the electric start solenoid is located and one at the front just above the oil fill tube mounting point. The fourth is located under the tank at the back to the right of the fuel shut off valve and further inboard. It is easy to remove.
I took off all the carb shielding and then removed the tank to adjust the governor, but it appears that you can remove the tank by itself. Remove the two 10mm headed bolts for the carb heat shielding to the left of the fuel shut off knob (after pulling off the knob first). Remove the two 12mm headed bolts by the solenoid for the electric start and the L shaped cover comes away. Loosen the front 12mm head mounting bolt, and remove the 12mm headed bolt just to the right of the fuel shut off, and I used a magnet to remove it. Then finish loosening the front mounting bolt and remove the bolt. The tank can be lifted up but not removed without removing the hose to the carb.
Adapting another tank to fit those mounts would be beyond my fabricating skills. Attached are some pictures to give you an idea of what is involved. Hopefully Ariens will introduce a larger tank for 2017.
Name:	Gas Tank 4 mounting points.jpg
ID:	80529   Click image for larger version
Name:	Gas tank rear mount 1 bolt.jpg
ID:	80537   Click image for larger version
Name:	Gas tank side mount 2 bolts.jpg
ID:	80545   Click image for larger version
Name:	Gas tank fuel shut off and hose.jpg
ID:	80553   Click image for larger version
Name:	Gas tank front mount 1 bolt.jpg
Town is online now
post #10 of 20 Old 02-22-2016, 09:30 AM
Just look at the outgoing location where the fuel shutoff is....the user is losing usable fuel right there(I know they did this so water and debri doesn't fowl the carb) but I've got a plan for more fuel that I just picked up at my ariens dealer this weekend
88racing is offline
