2015 Ariens Deluxe 24 jammed impeller - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 02-09-2016, 08:10 PM Thread Starter
Hi everyone
I just registered to this forum and just wanted to say "Hello" before I ask my first question.
I was blowing snow today and accidentally sucked up a magazine into the machine that jammed up my impeller and stopped my motor abruptly. I was able to remove the stuck magazine and restarted my snow blower, with only 2 pulls of the cord. I was wondering if this jam and sudden stall of my motor would of caused any damage to the motor? The machine is working OK but not sure if this caused any damage that may show up later. What part of the machine would of absorbed the jam?
Builder is offline
post #2 of 7 Old 02-09-2016, 08:15 PM
Likes (Received): 24
I have had this happen many times... Buried news papers.. I don't think you would suffer any damage. If you did not break a shear pin then the auger was not jammed. If it was the impeller you might stretch a belt a bit.
The gear box drives the auger from the impeller shaft, but is protected by the shear pins. The impeller comes directly off the pulleys, which are attached to the motor via the belts.. You didn't hurt the motor...
Ariens Platinum 30
Stuofsci02 is offline
post #3 of 7 Old 02-09-2016, 08:36 PM
Thanks (Given): 172
Thanks (Received): 335
Likes (Given): 473
Likes (Received): 831
In theory, the sudden stop could have stopped the engine so quickly that the engine's flywheel key could shear off. This would change the ignition timing. But if that had happened, the engine would immediately run differently, or not run at all. The flywheel key would probably either shear off, or wouldn't, it's unlikely you could partially-damage it.
So if it started fine, and ran normally, then the engine is probably fine, and there's nothing to worry about.
post #4 of 7 Old 02-09-2016, 08:40 PM
Likes (Received): 54
In this day and age, ya'll still subscribe to newspapers ?
mobiledynamics is offline
post #5 of 7 Old 02-09-2016, 08:41 PM
Thanks (Given): 172
Likes (Given): 450
Likes (Received): 1029
Please read through this thread..
https://www.snowblowerforum.com/forum...mber-safe.html
post #6 of 7 Old 02-09-2016, 08:43 PM
Thanks (Given): 172
Likes (Given): 450
We haven't had TV since 1991 so we read newspapers.
Also internet news.
post #7 of 7 Old 02-09-2016, 09:30 PM
hfjeff's Avatar
Likes (Received): 13
I would not be concerned. If everything is working fine then forget about it. If it is going to show up later then deal with it then.
Toro 1128 HD PowerMax, 342cc, 16.5 ftlbs, 11+ HP
Ariens 722, 7HP single stage
hfjeff is offline
