Is this a 1960 Ariens with a replaced drive train? - Snowblower Forum : Snow Blower Forums
post #1 of 19 Old 02-09-2016, 10:46 PM Thread Starter
Likes (Received): 12
Going to pick this up tomorrow. Couldn't tell by the pictures or owner if it's 1960.
Does anyone know if they used that particular Lauson sticker besides 1960 on the engine?
ariens snowblower
Thanks and fingers crossed. I'll update either way.
1961 Ariens 10ML-35
1963 Ariens 10M-L60D
1969 Ariens 10970
rnaude241 is offline
post #2 of 19 Old 02-10-2016, 12:21 AM
G_P
I'm no expert, but it looks old enough to be a 60. Someone added on the electric start and moved the gas tank farther outboard at a later date. IIRC the early electric start motors were round.
The numbers from the tags on the motor and machine will help narrow it down considerably. Ariens still has all the records from the 60's and if you Email them, they'll go dig through the paper files to see if they can find the year your machine was built.
1963 Ariens Sno Thro
197? Toro 724
G_P is offline
post #3 of 19 Old 02-10-2016, 05:11 AM
Thanks (Received): 149
Likes (Received): 543
At 50.00, i would get it .... worst situation, put a 6.5 hp Predator on it for 99.00 ..... They are great machines, these older ones, I have 2 ... a 10M6 and a 10M4, both with new engines .....
You also want to consider SnowHog or Trak tires ....
oneacer is offline
Likes detdrbuzzard, 43128 liked this post
post #4 of 19 Old 02-10-2016, 05:40 AM
Thanks (Given): 590
Likes (Given): 4366
Likes (Received): 1742
Fifty bucks, oh yah !!
post #5 of 19 Old 02-10-2016, 06:52 AM
Thanks (Given): 11
Thanks (Received): 111
Likes (Given): 19
Likes (Received): 311
That is just amazing. 56 years old, and from appearance at least seems to be in pretty good shape.
ELaw is offline
post #6 of 19 Old 02-10-2016, 07:19 AM
Likes (Given): 1885
Likes (Received): 663
get the numbers off of it and check scott's ariens info web page
post #7 of 19 Old 02-10-2016, 07:50 AM Thread Starter
The more I look at the pictures the more I don't think it is a 1960. The engine sticker that says Lauson seems like the same as the 1960's on Scots website, however the carb looks updated. Perhaps that was just replaced/modified. I know it doesn't have the gear drive but was hoping it was a modified version. If the engine is indeed a 4.5hp I am not sure what to think.
1961 Ariens 10ML-35
1969 Ariens 10970
post #8 of 19 Old 02-10-2016, 08:57 AM
Thanks (Given): 72
Thanks (Received): 397
Likes (Given): 182
Likes (Received): 931
(copy of an email I sent to Ryan about this machine)
Hey Ryan,
looks interesting! It could be a 1960..hard to say yet though..
yes, I think that style of nameplate was used in 1960..but if it is a 1960, then thats probably not the original nameplate.
A 1960 with an unmodified transmission is very obvious..it has the shifter:
but many 1960's were retrofitted with a friction disk..
For those modified units, there are two main clues to it being a 1960:
1. If the nameplate was not replaced, it should still have the shifter diagram attached:
although it could have been cut off..if so, that should also be fairly obvious.
the nameplate could also be replaced.
2. The biggest clue is the engine..*only* 1960 models had the 4.5hp engine.
Lauson H45D.
So if it has one, or both of those, its a 1960!
If it has neither, its probably a 1961 or 1962.
post #9 of 19 Old 02-10-2016, 10:06 AM Thread Starter
Thanks Scot. I am hopeful, but not too sure.
As I said the engine decal (not the tag as that's not pictured) looks exactly like the 1960's on your site. See here the left engine is the one I am trying to identify and the right is the 1960 from Scot's site:
And here is what my 1961 engine decal looks like:
As you can see my 1961 is very different! Finally I believe the 1962 changed to a rectangle heater box more common with the 10,000 series blowers:
Anyway, without the engine tag or body tag I won't know for sure until I see it.
1961 Ariens 10ML-35
1969 Ariens 10970
post #10 of 19 Old 02-13-2016, 07:59 AM
Thanks (Received): 57
Likes (Given): 425
Likes (Received): 139
So did you get it home yet ????
Phil
Ariens 2 foot SHO
1894 is offline
