Measure tracks? - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 02-11-2016, 02:59 PM Thread Starter
Measure tracks?
Hi, everyone. Looking to possibly use Ariens tracks for a project.
Would anyone with a tracked machine mind measuring the width and circumference (length) of a track for me?
Please list which model it is in case track sizes differ between models.
Thanks very much,
Nick
DakarNick is offline
post #2 of 8 Old 02-14-2016, 06:02 PM
Measure Tracks?
I have a just purchased new Ariens Compact 920022 (208 cc engine ) with tracks. It is a 24" 2 stage machine. The tracks have a 5 1/2" width, and a 46 1/2" circumference. This was measured to the nearest 1/4" using a tape measure, pulled tightly.
I hope this was helpful.
deecee60
Last edited by deecee60; 02-16-2016 at 05:05 PM. Reason: Left out digit in model number
deecee60 is offline
post #3 of 8 Old 02-15-2016, 09:03 AM
Thanks (Given): 66
Thanks (Received): 123
Likes (Given): 111
Likes (Received): 157
Originally Posted by deecee60 View Post
I have a just purchased new Ariens Compact 92022 (208 cc engine ) with tracks. It is a 24" 2 stage machine. The tracks have a 5 1/2" width, and a 46 1/2" circumference. This was measured to the nearest 1/4" using a tape measure, pulled tightly.
deecee60
Would the length be over the tread or the side of the track or the inside surface of the track. Likely important for the OP.
Town is online now
post #4 of 8 Old 02-15-2016, 09:51 AM
Likes (Received): 483
OP,
Are you considering Ariens only tracks?
As you can find an older inexpensive Craftsman, MTD or other tractor part of a track unit and have all needed components.
YSHSfan is online now
post #5 of 8 Old 02-15-2016, 08:13 PM
Measure Tracks?
I measured the circumference of the track by placing the tape measure around the outside of the track so that the tape measure is flat against the rubber cleats of the track. I keep the snowblower on top of a furniture dolly and each track overhangs the side of the furniture dolly by about 1.5 inches. This allowed me to wrap the tape measure completely around one of the tracks (top and bottom) to measure the circumference. My machine is brand new, so the cleats have no wear whatsoever. The tape was pulled tight around the track to minimize any slack in the measurement.
deecee60
deecee60 is offline
post #6 of 8 Old 02-16-2016, 10:02 AM Thread Starter
deecee60
Very helpful, thanks!
I can account for the thickness of the track. I'll have a tensioner I can adjust.
Originally Posted by hsblowersfan View Post
OP,
Nope, not only Ariens. But they're the only brand I didn't have measurements for.
deecee60
Thanks again!
post #7 of 8 Old 02-16-2016, 09:24 PM
db9938's Avatar
Thanks (Received): 143
Likes (Received): 297
Just FYI, Ariens sells their track setup ala carte, to convert your wheeled machine into a track. It appears to have the bracketry, tensioner, and idlers already setup. It's not cheap, but if you are buying the tracks, then cheap is not a concern. Some of my machines, the last time I looked, were $218 per side. So, what Ariens offers is a bargain.
http://parts.ariens.com/product-p/72102500.htm
post #8 of 8 Old 02-17-2016, 12:35 PM Thread Starter
Ariens® Sno-Thro Track Drive Kit
Thanks. Yeah, I've seen those. Even as low as $500. But that's a lot of money for an idea that may not work! If my idea works I'll probably go that route.
