Need Helicon Gear and Pinion - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 02-16-2016, 03:49 PM Thread Starter
Hi,
About two months ago, I bought an Ariens 10M L60D Sno-Thro Snowblower. The S/N is 258xx. Since it had not snowed enough to use it until last week, I used the time to familiarize myself with it, and to refurbish as much of it as I could. Scot's website (The Ariens 1960's and 1970's Sno-Thro info site.) was of tremendous help.
Well, all that waiting, and the day finally came. It snowed enough to try the snowblower, and it worked great! Since 1991 I had been using plows to clear snow, and they had always left mounds on the side of my driveway that I would ultimately get hopelessly stuck in. This was my first snowblower, and it left no mounds. I was ecstatic! This machine is absolutely the best!!!
Now, for the bad news. I used it again over the weekend, and the auger stopped rotating after catching a piece of gravel. After some disassembly, it appears that someone put some regular bolts into the auger driveshaft, where shear bolts were supposed to be. Since the shear bolt did not break, the gears in the gearbox broke.
The outside of the gearbox has the numbers 10180 on it. Using information from Scot's website, I believe that the proper Helicon Gear is P/N 10183, the proper Helicon Pinion is P/N 10177, and the Shear Bolt is P/N 10195. Would anybody have any of the above items for sale? I would like to buy either the individual parts, or an assembly that includes everything except for the impeller and the auger driveshaft.
Thank you,
Greg
[email protected]
Greg S is offline
post #2 of 10 Old 02-16-2016, 04:27 PM
check the roll pin in the gearbox that holds the gear to the shaft. you might get lucky
post #3 of 10 Old 02-16-2016, 04:28 PM
Thanks (Received): 28
Likes (Received): 58
I am sure someone here has them. I am going to look at a four snowblower bundle, two are old ariens. I will keep you in mind.
td5771 is offline
post #4 of 10 Old 02-16-2016, 04:31 PM
td5771 is offline
post #5 of 10 Old 02-16-2016, 04:40 PM
Thanks (Received): 195
Likes (Received): 816
Have Available. Send PM.
Jackmels is offline
post #6 of 10 Old 02-17-2016, 10:18 AM Thread Starter
I checked that. It is still good.
I removed the forward drain plug, and tried to drive the roll pin out through the drain hole with a punch, so that I could remove the helicon gear. Unfortunately, the roll pin was longer than the space between the shaft and the inner gear casing. The pin would not come out. I managed to get the pin back into place though, and all is fine again.
Greg S is offline
post #7 of 10 Old 02-17-2016, 10:19 AM Thread Starter
Thank you.
Greg S is offline
post #8 of 10 Old 02-17-2016, 10:21 AM Thread Starter
It is good to know that the parts are still available on E-bay. I tried the factory and several small parts suppliers, and they did not have anything related to the gearbox.
Greg S is offline
post #9 of 10 Old 02-17-2016, 10:41 AM Thread Starter
PM sent. These are some of the dimensions of the entire assembly.
Greg S is offline
post #10 of 10 Old 02-17-2016, 11:08 PM
Thanks (Given): 588
Thanks (Received): 769
Likes (Given): 4356
Likes (Received): 1736
to the forum Greg
