Ariens 32" hydropro 926517 electric starter question - Snowblower Forum : Snow Blower Forums
post #1 of 31 Old 02-17-2016, 11:26 AM Thread Starter
Thanks (Given): 21
Thanks (Received): 17
Likes (Given): 96
Likes (Received): 78
Angry Ariens 32" hydropro 926517 electric starter question
Spring is near and so is summer! I want to get ready for next year with a new snowblower, preferably a 32" Ariens professional quality machine to replace my old 32" Bolens!
But there is a problem. The 32" hydropro currently offered by Ariens operates with a 12vdc starter. That might be OK for a guy that carries a machine around in a truck but not for a home owner. OK, sure, maybe a home owner does not need a professional quality machine, but this home owner will only purchase pro quality.
So my question is can the 926517 model's electric starter be converted/changed to 120vac with a simple swap of the starter? I just do not want to put up with a battery and it's problems.
Don't know why Ariens did away with the 926054 that did use a 120vac starter. Also not sure if that model offered the same steering system as the current model. If the only difference is related to the starter, maybe I should look for a used 926054. A 36" machine is too big and although less expensive, I want to avoid a 28".
Thanks--
Foggy
foggysail is online now
post #2 of 31 Old 02-17-2016, 11:36 AM
Thanks (Given): 588
Thanks (Received): 769
Likes (Given): 4354
Likes (Received): 1736
I can't say specifically without knowing the engine but all the older engines would swap 12V/120V starters. Same mounts.
If you call a dealer they should be able to tell you if there is one available and the price and P/N.
If you know the engine we could look it up too.
http://www4.briggsandstratton.com/mi...log_MS3880.pdf
post #3 of 31 Old 02-17-2016, 05:26 PM
Likes (Given): 9
Why would you think the 12v starter would be a problem?
My lawn tractors don't have a problem when they sit over the winter. They start right up in the spring. Same thing for a blower sitting over the summer?
Zedhead is offline
post #4 of 31 Old 02-17-2016, 05:45 PM
Thanks (Given): 72
Thanks (Received): 397
Likes (Given): 182
Likes (Received): 928
12V: Needs a battery.
120V: No battery.
12V: Battery will eventually need to be replaced, = $$.
120V: No battery.
12V: Batterys dont like cold..might have trouble starting.
120V: Electrical outlet not bothered by cold.
The only advantage to a battery on a snowblower is if you are a commercial user, and are bringing the snowblower to multiple job sites..
but for a homeowner, 120V starter is soooooooo much better.
you are starting the snowblower in your garage, always.. an extension cord is right there on the wall. no battery to hassle with..no contest, 120V wins by a landslide.
sscotsman is offline
post #5 of 31 Old 02-17-2016, 05:49 PM
Thanks (Given): 21
Likes (Given): 172
Likes (Received): 28
Wait until you get older and you may change your tune.
AriensPro1128 is offline
post #6 of 31 Old 02-17-2016, 05:53 PM
Thanks (Given): 172
Thanks (Received): 335
Likes (Given): 475
Likes (Received): 834
I've never had a blower with battery start. But looking at Ariens' high-end offerings the other day, I did notice the battery start on one model (probably this one), and it kinda got me thinking.
I'd argue that tractors are most often used in the summer, so the warmer weather makes the battery happier, and the oil less viscous, making it an easier scenario. And if I can't cut my grass right now because the battery is flat, I can probably wait an hour to let a charger do its job.
For my situation, I would prefer AC-start. 99% of the time, the power will be on. My blower lives in the garage, so an outlet is 10 feet away. So I have infinite cranking time available, if the engine is being difficult. I have to let the starter motor cool, naturally, but that applies to either type.
With battery-start, you don't need a cord, of course. Great if the blower lives in an unpowered shed far from the house. But if the engine is having trouble starting, maybe because it's really cold, or carb issues, that could be trouble. You may only get a few attempts to start it, before the battery starts to weaken. After that, if you can't pull-start it, you might have to hook a charger to the battery for a while, before trying again.
A bunch of us saw that this weekend with our cars in the really-cold snap here in the northeast. The engine gets harder to spin, at the same time that the battery gets weak, an unfortunate combination. My car *normally* starts fine, but it had a hard time this weekend.
Now, normally, yes, the engine should start with a few pulls, or a few seconds of cranking. But we all know that sometimes things happen, and it needs a little more time. If you're relying on the electric start (maybe you have a bad shoulder), and the battery goes flat, while you need to get to work (and don't have an hour to recharge it), that's no good.
This difference was also going through my mind when reading some reviews of battery-powered (cordless) snowblowers, including an Ariens model, vs corded. I'll take my corded electric Toro any day of the week, vs cordless, for my situation. Stopping in the middle of clearing extra-heavy snow due to a dead blower battery? No thanks.
Edit: I see that Scot just made my points, more concisely
post #7 of 31 Old 02-17-2016, 05:58 PM
Likes (Given): 9
I rarely ever use my blower when I don't have to shut it off one time away from a 120V outlet. Out at the EOD, usually.
I'm actually looking at a 13 HP engine with a 12v starter to swap onto my 1032.
With the OHV engines there is a compression release. With the 12V starter and a decent battery, I'd imagine you could crank it till the starter over heats
Zedhead is offline
post #8 of 31 Old 02-17-2016, 06:02 PM
Thanks (Given): 11
Thanks (Received): 111
Likes (Given): 19
Likes (Received): 311
Scot,
You make some good arguments, but that particular one has one huge flaw: what if your engine stalls? Due to running out of gas or any other reason like heavier-than-expected EOD snow?
My driveway is 300' long so in that scenario I'd face the choice of using a 300' extension cord which is very unlikely to work (especially as I don't own one that long), or pushing my ~350 lb. machine all the way back to the garage. Okay scratch the "I" because I always use the pull starter, but my wife would NOT be happy if she were using the machine and found herself in that predicament. And as time passes neither of us are getting any younger... or stronger!
ELaw is offline
Likes RedOctobyr, help liked this post
post #9 of 31 Old 02-17-2016, 06:05 PM
Likes (Given): 9
I dunno, I can't think of a reason that would shy me away from a 12V starter setup
Zedhead is offline
post #10 of 31 Old 02-17-2016, 06:33 PM
Thanks (Given): 172
Likes (Given): 475
Originally Posted by ELaw View Post
Scot,
That's certainly a fair point. It's a scenario that's admittedly not on my radar, because my driveway isn't longer than my extension cord
My comments above were for *my* scenario and experience, my apologies if it sounded like I was trying to imply they must be correct/valid for everyone.
You're absolutely right, there are situations where requiring a cord will be a problem. Shoving these machines manually can be difficult, especially with tracks, as I understand it. More so if you have to go uphill.
I would still rather have an AC-powered starter, personally. For those that prefer battery-powered, I'm glad we all have options!
Likes AriensPro1128 liked this post
