Checking Oil Question? - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 02-18-2016, 02:13 PM Thread Starter
I have a 2015 Ariens Deluxe 24" with the 254cc engine. I have read and heard two different ways to check the oil level in the Arienx AX LCT engines.
First Method: Some say to pull the dipstick, wipe it off and just put it back in letting it rest on top of the fill spout.
Second Method: Quote from Ariens AX Snow Manual
ENGINE OIL LEVEL CHECK
Check the engine oil level with the engine stopped and with the engine in a level position.
1. Remove either side mounted filler cap dipstick or high oil fill dipstick and wipe it clean.
2. Insert the dipstick into the filler neck and turn clockwise until fully seated. Then remove the dipstick by turning it counter-clockwise.
Check the oil level shown on the dipstick (179/208/254cc only).
3. Securely screw in the filler cap/dipstick. Running the engine with a low oil level can cause engine damage. Always check the
engine oil before start up.
So should it be resting on top of the fill tube, or fully seated?
Thanks & Confused
Ariens 24" Deluxe
My First Snowblower
No No No I don't shovel it no more.
Got tired of waking up on the floor.
Smitty4ut is offline
post #2 of 11 Old 02-18-2016, 02:17 PM
Thanks (Given): 67
Thanks (Received): 60
Likes (Given): 115
Likes (Received): 81
Do what the Arien's manual says.
I have always seated it to get the proper level. Whether it was a car PS pump or small engine. Never had an issue.
Current machines
Ariens 926LE
Toro-8-2-4 is offline
Likes Smitty4ut liked this post
post #3 of 11 Old 02-18-2016, 02:19 PM
Thanks (Received): 33
Likes (Received): 54
Seated.
FWIW, I removed the plug off the low port on the block and just used that as the old tried and true way. Much easier IMO as well. It's fill when the oil is right onto of the threads....aka, before it's about to overflow.
mobiledynamics is offline
post #4 of 11 Old 02-18-2016, 02:19 PM
Likes (Received): 42
If the manual says screwed in, screwed in. Truthfully, the difference in the reading is insignificant. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
8 hp MTD hybrid plow
motorhead64 is offline
post #5 of 11 Old 02-18-2016, 02:34 PM Thread Starter
Thanks for the replies, and I had planned on following the manual. I do believe the difference in it being tight and resting could matter. If you look at how close the 2 holes on the dipstick, it wouldn't take much.
Again thanks for the replies, I was unsure where all of the misinformation comes from.
Ariens 24" Deluxe
My First Snowblower
post #6 of 11 Old 02-18-2016, 02:43 PM
Thanks (Received): 112
Likes (Received): 298
My Briggs and Stratton engine specifies SCREW IN the dipstick to get an accurate reading. Kind of a pain, but that's what I do. The difference between screwed in and not screwed in would be at least 1/2 inch on the level, so if you were to check with the stick not bottomed, and fill based on that, them you would be overfilled by the length of the threads.
Kohler Courage lawn mower engines specify DO NOT screw in the dipstick, just remove, wipe it down, then reinsert and check Level.
Last tecunseh I had, the dipstick was a twist/lock design, so it was no brainer.
Yours is an LCT, and the manual says screw it in, I would screw it in.
Work fascinates me.
skutflut is online now
Likes Smitty4ut, Kiss4aFrog liked this post
post #7 of 11 Old 02-23-2016, 11:04 AM
Dipstick
Yup,
I know what you mean--you mileage may vary. The Briggs and Tecumseh motors are usually checked while screwed all the way in.
On some Asian motors, you pull the dipstick out, wipe it, and rest it on the top of the opening (like the Subaru on our Cyclone Leaf Rake) where you rest it at the top to gauge the oil level.
At the end of the day, it is whatever you are told in the owner's manual as the mfg. designs it to their standards.
QR
Quickrick is offline
post #8 of 11 Old 02-23-2016, 11:54 AM
Thanks (Given): 590
Likes (Given): 4368
Likes (Received): 1742
It's likely from folks who haven't read their manual or all the engines they have had so far are one way so they think all are the same.
post #9 of 11 Old 02-23-2016, 02:25 PM
Likes (Received): 21
I wish briggs had it where you didn't have to screw it down to get a good reading. seems to me turning the thing makes it harder to read on an already hard to see yellow dipstick.
brickcity is offline
post #10 of 11 Old 02-24-2016, 12:02 AM
Thanks (Received): 87
Likes (Given): 57
Likes (Received): 269
You can always spray paint the end of that dip stick white.. make it easier to see.. Just a thought.
GoBlowSnow is offline
