2010 Ariens Deluxe 24 921019 Subaru - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 02-25-2016, 03:44 PM Thread Starter
Hi-
New member from PA. I have a 2010 Ariens Deluxe 24 921019 with a Subaru SX21 engine on it. This is the first year I have had to do anything to it other than lube and change the oil. I had to replace the traction belt. I followed the videos put out by Ariens, changed the belt, adjusted the cables, and realigned the bucket. Easy job and very satisfying to complete. I had not planned on joining the forum but while searching here for info on this blower I noticed that none existed.
I linked the specs below. It's a basic machine that gets the job done. No light, no remote chute deflector, pin lock wheels. Five controls: auger, drive, speed, chute rotation, manual chute deflection. Throws the snow very far for the smallish engine. Starts with one pull.
The XS gearcase has leaked from the rear seal since new, I just top it off before each use and park it over some newspaper, I had been using Ariens L3 but just picked up a quart of 75w140 for 1/2 the price of the 8 oz L3.
Other than that the SX21 Subaru sips gas, I am always amazed at how little it uses. I had to adjust the speed on it using a sirometer, it was low from the factory, now it's at 3600RPM.
Thanks for the great forum -Joe
specs here:
Ariens Deluxe Sno-Thro® Snow Blower 24" - ST24E 211cc
Enlarge Image
Ariens Deluxe Sno-Thro Snow Blower 24" - ST24E 211cc
Manufacturer: Ariens
Model: 921019 Discontinued
(No reviews)
Be the first to
Write a Review
Grade Surface Type Snow Type Surface Area Amount Per Snowfall This model has been discontinued and is no longer for sale.
An Ariens Deluxe Sno-Thro makes light work of the heavy stuff, relentlessly carving out a 24-inch wide path. Always on the attack, this machine features a heavy-duty XS Gear Case that provides additional power especially in extreme snow conditions. Plus, the steel THF chute discharges snow higher and farther. That's domination that's an Ariens Deluxe.
Power Source
  • 211cc Subaru Robin engine
  • 120 volt electric start with recoil back-up
  • 2.9 quart fuel capacity
  • 6 forward speeds / 2 reverse speeds
Structure
  • 24" clearing width
  • 21" housing height
  • 3' - 50' throwing distance depending on the snow conditions
  • 200 2.5x ice drill manual chute control
  • Dual-handle interlock system
  • Reversible skid shoes
  • Standard clean-out tool
  • All steel construction
Internal System
  • Heavy-duty aluminum XS gear case
  • Steel serrated auger
  • Three blade, 14" steel impeller
  • Pin lock axle
Tread Control
  • 15 x 5 Directional snow tread tires
psjoe is offline
post #2 of 11 Old 02-25-2016, 05:40 PM
Likes (Given): 1885
Likes (Received): 663
hello psjoe, welcome to SBF and thanks for the info
post #3 of 11 Old 02-25-2016, 05:48 PM
Thanks (Given): 82
Thanks (Received): 173
Likes (Given): 420
Likes (Received): 664
welcome to SBF !
doesnt another member here have a blower with a subaru powerplant ? i think there is a thread about a nla head gasket maybe?
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #4 of 11 Old 02-25-2016, 06:13 PM
Likes (Given): 1885
Originally Posted by nwcove View Post
welcome to SBF !
that was a toro 828 with a mitsy motor
post #5 of 11 Old 02-25-2016, 06:16 PM
Thanks (Given): 82
Likes (Given): 420
ahhh.....my mistake !!
28 " Ariens Sno Tek
Toro CCR ss
post #6 of 11 Old 02-25-2016, 06:40 PM
Thanks (Given): 102
Likes (Given): 274
Joe, welcome aboard !
uberT is offline
post #7 of 11 Old 02-25-2016, 06:59 PM Thread Starter
Hi guys thanks.
I did a bit more research and came up with this press release from 2009. It's from Marindustrial out of Canada. It has the 921019 in it. I wonder what the story of Ariens and Subaru is. This machine was purchased in the US. Maybe sold here as a stop gap to satisfy demand? It seems like only a one year thing?
http://www.marind.ca/medias/pdf/mari...s_Sept2009.pdf
psjoe is offline
post #8 of 11 Old 02-25-2016, 08:13 PM
Thanks (Received): 87
Likes (Given): 57
Likes (Received): 269
GoBlowSnow is offline
post #9 of 11 Old 02-25-2016, 08:29 PM
Likes (Received): 280
post #10 of 11 Old 02-26-2016, 06:31 AM Thread Starter
Can't be that rare in the US here is one I found on CL in NJ!
Ariens Deluxe 24 Snow Blower - $600
© craigslist - Map data © OpenStreetMap
(google map)
condition: excellent
make / manufacturer: Ariens
model name / number: ST24LE 921019
Used Ariens Deluxe 24 Snow blower for sale. Light use over past 4 years. Excellent condition, electric start. MODEL 921019
psjoe is offline
