New Platinum 24 starting issue?? - Snowblower Forum : Snow Blower Forums
post #1 of 24 Old 12-23-2013, 09:50 PM Thread Starter
OK, it starts fine. First pull yesterday and normally on the second pull at other times but here is the issue: Neighbor stopped to talk so I shut it off by simply throwing the switch from on to off. He left and I clicked the switch back on and gave it a pull and then another pull and yet another. After 10 pulls without even a hit I decided something must be amiss! I pulled it into the garage and let it sit for a few minutes. I don't remember if I choked it again or not, shouldn't have needed it as it was still plenty warm, at any rate on about the 3rd pull it finally started.
I ran it for awhile and shut it off the same way a little later just to see if the problem still existed. Shut off the switch and tried starting it again. Same problem. It starts great cold but sure doesn't seem to start great warm. This is a brand new machine. Any pointers I could use to start it next time?
fishrman is offline
post #2 of 24 Old 12-23-2013, 09:54 PM
Thanks (Received): 52
Likes (Given): 266
Likes (Received): 108
Pretty much the same with me. It seems like you need to give it at least partial choke to start even when warm. Most times at least. If there's pointers, I'm all ears.
Larry
Larry
Snow Removal Equipment:
2014 Ariens Platinum 24
Blue Hill is offline
post #3 of 24 Old 12-23-2013, 10:06 PM
Thanks (Given): 173
Likes (Given): 457
Likes (Received): 1034
Larry
What he said Δ
post #4 of 24 Old 12-23-2013, 11:01 PM
Is that with the AX engine or Briggs?
I have the briggs and it does the same thing. I have to choke it slightly to get it to pop off then immediately after I turn choke off.
Doesn't seem like it should be this way but I guess it is.
Benny365 is offline
post #5 of 24 Old 12-23-2013, 11:52 PM
I think that is the nature of the new motors. I have a snow tek and I shut if it off with the switch and refilled with gas and had to use choke too get it started also.gayland
BB Cub is offline
post #6 of 24 Old 12-24-2013, 12:02 AM
problem might be that the carb is set to run lean and we will have to use choke on restart. might have to try and use primer and see if that works. maybe somebody will chime in and explain this to us better.
BB Cub is offline
post #7 of 24 Old 12-24-2013, 01:55 AM
Thanks (Given): 589
Likes (Given): 4362
Likes (Received): 1741
When you say new carbs with lean mixture, I think you've nailed it. Be glad you only have to choke it to get it restarted and don't need to choke it to keep it from surging and have to operate with it on The troy is that way.
post #8 of 24 Old 12-24-2013, 02:10 AM
You mean they are supposed to run without the choke somewhat engaged? I think all 7 blowers that I use (Ariens and John Deere) have to have either 1/4 choke or 1/2 choke engaged to run the thing after starting otherwise it sputters and looses power. Most except the new Deluxe 30 will start with 3/4 or full choke on, even after they have been running awhile. The Deluxe 30 will start with 4 primes on 1/2 or 1/4 choke but still requires 1/4 choke to run without sputtering.
Ryan is offline
post #9 of 24 Old 12-24-2013, 03:01 AM
Thanks (Given): 589
Likes (Given): 4362
If they are brand new it's the jetting of the carb. If they are a year or a few old it can be varnish or crap that found it's way to the jets.
My 2410 Troy is know for it and there was even a guide on what drill bits to use to open up the jets to cure the problem if cleaning doesn't help. I already have the mini drill bits on hand for this spring when I don't need the Troy and it's warmer. It's a pain to get to the carb as there are a couple covers and a number of screws to get to the two that hold the carb. Already pulled it once to clean and it don't do anything. Didn't have the drill bits at the time
post #10 of 24 Old 12-24-2013, 08:33 AM Thread Starter
Larry
Well, glad to hear someone else is having the same issue. Maybe I will write Ariens. They surely have an answer.
fishrman is offline
