Motor Mount Bolts - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 03-24-2016, 06:41 PM Thread Starter
Motor Mount Bolts
Any of you re-power gurus know how the mounting bolts are fastened to the chassis .
The model I'm repowering is a late '60's 6 HP Sno-Thro ( the one that accepts all the front attachments ) .
Digger 66 is offline
post #2 of 15 Old 03-24-2016, 07:02 PM
Thanks (Received): 39
Likes (Given): 53
Likes (Received): 100
They are pressed on. A few hits with a hammer and they come right out
Scott
69 ariens
toro 721r
toro 926 hd oxe
69ariens is offline
post #3 of 15 Old 03-24-2016, 08:04 PM
Thanks (Received): 173
Likes (Given): 415
Likes (Received): 664
fwiw.....i cut the studs off about 1/4 " above the chassis and welded extensions on. it seemed like the easiest option for me as there isnt much room to get anything like hands or tools up past the transmission parts.
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #4 of 15 Old 03-24-2016, 08:38 PM
Thanks (Received): 195
Likes (Received): 816
I have cut the studs off, and then drilled through and tapped the hole to accept 5/16 bolts. This is especially helpful on the 73-4 10000 series forward bolts.
Jackmels is offline
post #5 of 15 Old 03-24-2016, 09:49 PM
They are spot welded. I believe they have 3 spot welds each. I have knocked them out with a sledge hammer.
post #6 of 15 Old 03-25-2016, 05:13 AM Thread Starter
Thanks for the replies fellas .
I was whacking them pretty good with the four-pounder & they weren't budging .
post #7 of 15 Old 03-25-2016, 06:18 AM
Thanks (Given): 14
Likes (Given): 44
Likes (Received): 50
I don't understand why but I've had the best luck cutting them with angle grinder so there's about 1/4" then used a framing hammer to whack them out, maybe it's the heat?
Rob711 is offline
Thanks Digger 66 thanked for this post
Likes Digger 66 liked this post
post #8 of 15 Old 03-25-2016, 07:44 AM Thread Starter
I think I'm going to grind them off flush , center-punch , drill & tap as stated above .
Thanks again to all that replied .
-Gene
post #9 of 15 Old 03-25-2016, 10:24 AM
If you do the drill and tap method, I suggest adding nuts on the rearward bolts inside the chassis; they are easy to put on, and use Red Threadlocker on all the newly tapped threads as well. GL!
Jackmels is offline
post #10 of 15 Old 03-25-2016, 05:04 PM Thread Starter
I would add stainless aircraft type lock-nuts on all four .
