Model 924040. Just received for Nada... :) - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 03-27-2016, 02:56 PM Thread Starter
Blackstar's Avatar
Likes (Received): 18
Just got this from a neighbour this afternoon. I remember his Father using it years ago. He said it hasn't run in about 2 years and had it sitting out behind his shed uncovered.
I originally was thinking of passing this on to an elder friend of mine who wanted a small blower to complement his Kubota tractor mounted blower. Something to do pathways, etc. Now I'm not sure what I want to do with it.
History is that it stopped blowing because the auger gearbox was gone, possibly from a piece of firewood picked up in the driveway.
Can't move the speed control lever... seems like the friction wheel is rusted onto it's shaft. Soaked everything in penetrating oil and will let it sit for a while.
Motor turns over freely and oil looks pretty clean. Doesn't seem to be any spark.
Tires were mostly flat and weather cracked but seemed to hold air when I blew them up...
Anyway... don't know if I will be keeping or not... here are a few pics...
Sorry... for some reason I can't post pics anymore...
Ariens Platinum 30 SHO- AX414, 20.0 lb.ft torque.
Blackstar is offline
post #2 of 15 Old 03-27-2016, 02:57 PM Thread Starter
Blackstar's Avatar
This is what pops up when I try to post pics...
Your submission could not be processed because a security token was missing.
If this occurred unexpectedly, please inform the administrator and describe the action you performed before you received this error.
post #3 of 15 Old 03-27-2016, 08:50 PM Thread Starter
Blackstar's Avatar
Model 924040. Just received for Nada... :)-edit1.jpg
Model 924040. Just received for Nada... :)-edit2.jpg
Model 924040. Just received for Nada... :)-edit3.jpg
Model 924040. Just received for Nada... :)-edit4.jpg
Model 924040. Just received for Nada... :)-edit5.jpg
post #4 of 15 Old 03-28-2016, 06:01 AM
Thanks (Received): 11
Likes (Given): 9
Likes (Received): 30
Is that an aluminum gear box? Didn't think 924s had them. I learn something new here every day! Well, the gear box is probably toast because the rakes are frozen on the shaft and the pin(s) didn't shear. That is NEVER fun to repair, in my limited experience.....
bwright1818 is offline
post #5 of 15 Old 03-28-2016, 10:16 AM
Thanks (Given): 66
Thanks (Received): 123
Likes (Given): 114
Likes (Received): 157
Looks like a candidate for a complete teardown and refinish the chassis and mechanicals. I have never done that, but I would think it takes time and dedication to find used parts that will replace the broken ones. There are lots of experts here that would help you make that machine like new in a short time, and they are very willing to share their expertise and experience.
Since you already have a nice new machine, what would you be looking to achieve in making that old machine work properly again?
Good luck.
Town is online now
post #6 of 15 Old 03-28-2016, 01:24 PM
Thanks (Received): 195
Likes (Received): 816
That model has an aluminum gearbox. The Shape of the bucket is a dead giveaway. I have parts available if needed. Shifter won't move tells me the friction wheel is frozen on the shaft. Clean up the shaft with sandpaper, wire brush, and pb blaster, and tap the friction wheel until it moves. Auger gear is probably shot.
Jackmels is offline
post #7 of 15 Old 03-28-2016, 04:05 PM Thread Starter
Blackstar's Avatar
Thanks for the replies. I sprayed penetrating oil on the moving parts to try and free them up. Haven't spent more than an hour just looking it over. It was free so I thought I'd take a look at any problems it has. Was hoping it would be a fairly easy fix to get running.
My new Platinum runs great but this was going to go to a friend of mine who wanted something small to clear his walkways, etc. after blowing out with his tractor. I like old machines and enjoy tinkering with them. If this one is too far gone It may pass on to other (wealthier ) hands.
The friend it was going to is retired and has a full functioning garage in his back yard so he'll probably enjoy working on it as much as I would. If he wants to give it a go I will surely be back looking for parts and advice. This is a great forum and have gotten help numerous times here.
Glenn
post #8 of 15 Old 03-28-2016, 04:07 PM Thread Starter
Blackstar's Avatar
Another thing I forgot to ask. Does this machine have a set of points for ignition? I mentioned to a guy at work about getting no spark when I pulled the start cord and he thought it had points.
Glenn
post #9 of 15 Old 03-28-2016, 04:34 PM
Thanks (Given): 16
Thanks (Received): 86
Likes (Given): 241
Likes (Received): 202
yes, it uses points.
db130 is offline
post #10 of 15 Old 03-28-2016, 04:43 PM
Thanks (Received): 48
Nice Dakota in the background.
94EG8 is offline
