Ariens deluxe 254 cu in AX fuel tank capacity - Snowblower Forum : Snow Blower Forums
post #1 of 16 Old 12-26-2013, 01:57 PM Thread Starter
Hello All
Had the new Ariens out for the second time, half done the drive and the engine started to surge. So I turned it off and tried to restart, without success . Surely I could not be out of fuel, only ran for about one hour or so last time out. Sure enough, filled up the tank and away she went. Checked the manual later, found out capacity is 2.7 liters which = .6 imperial gals. I must admit do not know how much fuel was provided by the dealer when delivered. After my MTD ( whiuch gave me grief by the way) which had a monster tank, the capacity of the Ariens seems somewhat small. All comments welcome. Thanks
The Nforesir
2014 Ariens Deluxe 24
Nforesir is offline
post #2 of 16 Old 12-26-2013, 02:23 PM
Thanks (Given): 72
Thanks (Received): 397
Likes (Given): 182
Likes (Received): 931
hmm..that does seem small.
used to be that 1-gallon tanks were the norm.
Perhaps with the downward trend in gas quality, they are now purposly making gas tanks smaller, so people can more easily drain, or run them dry, in the spring..
but thats just a guess..
It could also be completely arbitrary, and done for no real reason.
sscotsman is offline
post #3 of 16 Old 12-26-2013, 02:51 PM
Likes (Given): 1885
Likes (Received): 663
i think the smaller gas tanks has to do with looks, everything is more modular and those old big gas tanks just don't give the machine a nice clean look
post #4 of 16 Old 12-26-2013, 03:37 PM
Thanks (Received): 52
Likes (Given): 266
Likes (Received): 108
Mine has a 3.6 litre tank, which is just shy of an American gallon. I can go a couple of hours, but not much more than that. It is what it is. I'm just happy that everything else works great.
Larry
Snow Removal Equipment:
2014 Ariens Platinum 24
Blue Hill is offline
post #5 of 16 Old 12-26-2013, 07:52 PM
Thanks (Given): 590
Likes (Given): 4367
Likes (Received): 1742
I think your math is off. I looked up a Deluxe 24 and they say it's a 2.7L (2.9 quart) fuel capacity. So it's about 25% smaller than the "average" gallon tank.
Might want to talk to someone at a small engine repair shop or contact Ariens to see if there is a bigger tank that could be swapped on if you do find you are filling it more often than you want to.
What I found handy for filling and emptying my machines is a 12V pump they label should NOT be used with gasoline. I purchased mine at HomeDepot but I've seen them at northern tool and others.
post #6 of 16 Old 12-27-2013, 05:40 AM
I have the same motor / tank. I have 2200 sq ft of driveway plus about 100 ft of sidewalk, plus I usually do the neighbor's sidewalk and mailbox area. I do all this without refilling. The blower isn't out of gas, but I surely am at that point. I guess the tank is large enough, unless you're using the blower commercially.
Bruce
Brucebotti is offline
post #7 of 16 Old 12-27-2013, 09:14 AM Thread Starter
Thanks for all your comments, pretty sure my math is correct.
One US gal = 3.78 liters, 2.7 liters = .71 US gal
One Canadian gal = 4.5 liters, 2.7 liters = .60 Canadian ( imperial gal)
Looks like I better fill the tank every time I blow snow....Cheers
The Nforesir
Nforesir is offline
post #8 of 16 Old 12-27-2013, 11:27 AM
Yea, a fill up is the normal for most people before taking a mower or blower out. You can't really compare the smaller tanks on the new engines with the larger tanks on the old engines as the new engines use a lot less fuel too.
post #9 of 16 Old 12-31-2013, 08:51 AM
mkd
I just bought an ariens 921030 with the same gas tank and capacity. the screen in the filler neck of the tank is a good idea but makes filling the tank with a 5 gallon tank and funnel very difficult. I'm going to have to come up with a better gas can and spout to fill the tank. the 5 gallon cans with a big funnel that use to work on my old 924 won't work on the new 921. any ideas?
mkd is offline
post #10 of 16 Old 12-31-2013, 10:30 AM Thread Starter
I have used my 2 gal tank, with the small nozzle assembly that came with the tank, pretty sure a funnel will be difficult to use with the horizontal fuel level bar just below the neck of the filler tube. It's a slow process to fill the tank, but because of the 2.7 liter capacity it does not take that much time. Cheers
The Nforesir
Nforesir is offline
