1964 Ariens restoration with Predator 212 - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 05-01-2016, 09:34 PM Thread Starter
At the finishing stage of restoring 1964 Ariens 10ML60D. Original Tec engine was shot, got a bent piston ring rod, and bad crank shaft. put in a HF Predator 212, but the chute rod shaft is hitting the engine. The rotating teeth is not hitting the spocket. Any suggestions please?
ceng41 is offline
post #2 of 13 Old 05-01-2016, 09:54 PM
Thanks (Received): 195
Likes (Received): 816
Put a spacer under the engine to raise it. There is also some adjustment by loosening the 2 bolts that hold the crank assy to the chassis, and try a different angle. You can also lightly tap the sheet metal on the engine to gain some clearance. There's 3 suggestions.
Jackmels is offline
post #3 of 13 Old 05-01-2016, 09:56 PM Thread Starter
pictures attached.
ID:	86930   Click image for larger version
ceng41 is offline
post #4 of 13 Old 05-01-2016, 10:06 PM Thread Starter
Thanks for the quick reply, i was going to remove the sheet metal, maybe some kind of heat shield under the valve. But will try your idea to raise the engine up to gain some clearance.
ceng41 is offline
post #5 of 13 Old 05-02-2016, 11:27 AM
Thanks (Received): 173
Likes (Given): 415
Likes (Received): 664
Have you read through the repowering forum? Lotsa good info and ideas there.
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #6 of 13 Old 05-02-2016, 12:14 PM
Likes (Received): 303
I had to add a second u-joint and went over the top of the engine on my 924038 going from a Tec 7hp to LCT OHV 291cc. Mine had a short stub directly at the chute gear, then a relatively short straight rod to one u-joint, then up the handle. I put a second u-joint on the short stub, then the straight rod, then another u-joint to get back to the handle bars. The new engine carb covering caused too much angle to get back to the handle bars with only one u-joint. Our local ace hardware had metal rods for sale that could be drilled to accept the pins that hold the u-joints or the sleeve commonly found on Ariens. I know yours is different for the crank gear, but I think the diameter of the rods is the same
post #7 of 13 Old 05-02-2016, 02:46 PM
Thanks (Given): 14
Likes (Given): 44
Likes (Received): 50
Why is that sprocket so far from the chute? Swapping engines didn't do that, like others said, I persuaded the tin a bit and lowered the chute control mount on the handle. If that doesn't work for you two universal joints could make almost anything work. Good luck
Rob711 is offline
post #8 of 13 Old 05-03-2016, 06:34 PM Thread Starter
Here is a better picture of the chute rod situation. I will definitely check out the "repowering" fourm, that is if i can find the forum. Otherwise, i will remove the tin shield, i think it will give me enough clearance to raise the bracket up.
Thanks for all the suggestions.
ceng41 is offline
post #9 of 13 Old 05-03-2016, 08:11 PM Thread Starter
Yeah! Found the re-power forum under Snowblower repair and maintenance forum. There are couple posts showed the exact challenge that I am facing and their solutions. One is drill new holes to tilt the bracket up at an angle.
Sincere thanks to JACKMELS and HJMAES suggestions.
ceng41 is offline
post #10 of 13 Old 05-03-2016, 08:51 PM
Likes (Received): 483
Can you weld? IF so, make the rod that has the sprocket and the flex joint longer, so that it reaches the chute base and the other end is close to the base of the handle bar and you can use the flex joint to bring the remaining part of the chute rotating handle. You could bring the handle up to make it more convenient (sort of like this Yamaha)
