1960 Ariens 10M Project - Snowblower Forum : Snow Blower Forums
post #1 of 26 Old 06-22-2016, 12:13 PM Thread Starter
Likes (Received): 483
Hello everyone, as some of you may already know I am the owner of a 1960 Ariens 10M snowblower.
Cosmetically it is in ok condition. The 2 speed forward and reverse gearbox is not working (feels like it is stripped internally), it may be the very first thing that I take a look at. The engine is not working (feels like it may have a thrown rod-moves a litle both ways and stops), anyways it is not likely the original engine as according to Scot's site it should have a Lauson 4.5hp engine and instead it has a Lauson 5.5hp engine (might be a late 61 or early 62 engine). I will look at the engine after the gearbox is fixed (if possible), or I may use another engine instead.
I will try and post as progress is made (as time allows).
This is what I am starting with.........
YSHSfan is online now
Likes ELaw liked this post
post #2 of 26 Old 06-22-2016, 01:41 PM
Thanks (Received): 14
Likes (Received): 65
Wow, she's come a long way! They've stopped making those exposed augers a long time ago, before lawyers (and garage doors) had their say.
guyl is offline
post #3 of 26 Old 06-22-2016, 05:13 PM
Likes (Received): 12
That's awesome. Hopefully you can get it running. As for the gearbox, when I spoke to the guy selling it he had mentioned that it was replaced with a friction disc (also mentioned on Scot's page). So I am curious if that's the case or not. Good Luck!
1961 Ariens 10ML-35
1963 Ariens 10M-L60D
1969 Ariens 10970
rnaude241 is offline
post #4 of 26 Old 06-22-2016, 06:38 PM
AriensProMike's Avatar
Thanks (Received): 19
Likes (Received): 58
That's too bad on the engine. Look forward to the progress.
AriensProMike is offline
post #5 of 26 Old 06-22-2016, 08:19 PM
Likes (Given): 23
Likes (Received): 62
Wow, That's an oldie. Nice project. I like bringing old vintage engine powered
equipment back to life.
Lee
John Deere TRS32
Craftsman 1032 Drift Breaker
John Deere 1032
Bolens 1032
John Deere 1032 Project
lee h is offline
post #6 of 26 Old 06-22-2016, 09:51 PM
Thanks (Received): 41
Likes (Received): 98
AWesome!
Good luck and hope it all goes well.
As for the engine, just maybe a hunk of carbon on top of the piston. I've seen this happen a few times.
Keep us posted with your progress!
scrappy is offline
post #7 of 26 Old 06-23-2016, 12:19 PM Thread Starter
The original transmission was not really replaced, everything seems to still be there. What he did instead was to get a used "tractor" 62-63? with friction disc and used it with the blower attachment.
I will post pictures of the entire set up when I start to look into it.
post #8 of 26 Old 06-23-2016, 09:19 PM Thread Starter
Not too good news.....
Today I had some spare time and decided to look into the 10M gearbox. Not too good news, I have 2 worn/stripped outer gears (for forward speeds) but the worst part is the reduction gears are also shot (lack of lubrication I'm pretty sure).
I will have too look/think about the options that I have to bring it back to life......
Likes scrappy liked this post
post #9 of 26 Old 06-28-2016, 09:11 AM
Thanks (Given): 24
Thanks (Received): 34
Likes (Given): 15
Likes (Received): 24
Do you think you can use some old front auger gearbox parts (specifically the gears) in that drive gearbox? That part number 10105 on the housing is the same housing number as the old auger gearboxes. Maybe the internals will match up? Obviously the shaft lengths are going to be different, but maybe the gears are the same?
You could always so the friction disc conversion...would be cool to keep it orig though.
Have no ideas on those outer gears though, ugh!
Ray
1962 Ariens 10ML60
1979 Toro 524
1975 MTD Snowflite 4/22
Ray 1962 10ML60 is offline
post #10 of 26 Old 06-28-2016, 11:29 AM Thread Starter
That is exactly what I am hoping Ray, to use the large gear of an early (60-64) auger gearbox and its impeller shaft (properly machined to match the damaged one).
I am working on getting a spare 60-64 gearbox (10105 casting numbers).
The outer gears may still be usable, Ill find out about it when I reassemble it.
I really want to keep the drive train as the original design and not go for a friction disc.
I will post as progress is made.
