LED lights on Pro 28 - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 07-30-2016, 08:33 PM Thread Starter
I've been wanting to upgrade the lighting on my 2012 Ariens Pro 28 for some time now. I'm finally getting to it. I've been using this sticky "Upgrading your snowblower to LED lights" as a guide.
I'm no electronics expert so I could use some clarification on a few things.
First i'd like to use the Lemonbest lights shown on page 73.
Secondly, will I still need the 2200mfd 50v capacitors to clean up the "dirty" DC output?
What else do I need aside from a fuse holder? It appeared as though a 1 amp would be sufficient for 20w total?
Thanks,
Kelly
FWIW I didn't post any links because of the post count deal.
Turbo3Ariens is offline
post #2 of 13 Old 07-31-2016, 05:10 PM
liftoff1967's Avatar
Thanks (Given): 36
Thanks (Received): 45
Likes (Given): 65
Likes (Received): 94
I did not see Lemonbest post on page 73, so not sure what the set up is you wanna duplicate.
Yes you will need a capacitor. Not required, but I set mine up with (2) capacitors in parallel, in case one failed. I then put 1 amp fuses in line as well.
I do have a couple extra sets of brackets, both tall and short if your interested. I have sold a few sets to members here and they are happy with them.
liftoff1967 is offline
post #3 of 13 Old 07-31-2016, 05:16 PM
Thanks (Given): 36
Likes (Given): 65
Here is a link to my post on the details of both types of brackets, as well as a link to the you tube video of my set up.
https://www.snowblowerforum.com/forum...-brackets.html
post #4 of 13 Old 07-31-2016, 06:15 PM Thread Starter
My apologies, the Lemonbest lights were listed on page 62, post #616.
I was going to just drill holes in the side of the dash but after looking at your brackets I'm starting to reconsider it.
post #5 of 13 Old 07-31-2016, 09:29 PM
Thanks (Given): 36
Likes (Given): 65
it appears to me those lights would work.
Let us know how ya do.
post #6 of 13 Old 08-04-2016, 07:24 PM
Thanks (Received): 112
Likes (Received): 298
[QUOTE=Turbo3Ariens;1017681]I've been wanting to upgrade the lighting on my 2013 Ariens Pro 28 for some time now. I'm finally getting to it. I've been using this sticky "Upgrading your snowblower to LED lights" as a guide.
I might be missing something here, but if your load is 20 watts, and your output voltage from your alternator is around 13 - 14 volts, you might want to go with a 2 amp fuse. Watts = Volts X amps. Amps = Watts / Volts.
20 watts would be exceeding the 1 amp fuse rating. It might last a while, depending on the type of fuse you use, but it will fail if its always overloaded
Work fascinates me.
skutflut is offline
post #7 of 13 Old 08-05-2016, 06:43 AM Thread Starter
It's certainly possible. I don't claim to be an electronics expert. I just based it off of what others with similar setups said they were using in the thread I referenced above.
Still waiting on parts to arrive for the time being.
post #8 of 13 Old 08-06-2016, 05:44 PM Thread Starter
On the wiring diagram I see A.C. Lighting (yellow) and D.C. Charge (red). I assume I should tap into the yellow lead?
post #9 of 13 Old 08-06-2016, 06:53 PM
Thanks (Given): 36
Likes (Given): 65
"IF" my memory serves me correct, and that is going on 2 seasons ago when I did mine, yes, yellow is your wire.
post #10 of 13 Old 08-06-2016, 09:28 PM
Dpach's Avatar
I believe it is yellow. I routed the factory light lead wire through a single pole double throw switch and ran one side back to the factory light and the other through a bridge rectifier and a couples 2200 capacitors (included a couple 2amp fuse holders) to the new LEDS so I could have the factory light or the LEDs running depending on the situation .
Dpach is offline
