Plugging in the 2014 Ariens 28 Deluxe 921030 - Snowblower Forum : Snow Blower Forums
post #1 of 27 Old 12-29-2013, 04:01 PM Thread Starter
So I just picked up my first snowblower yesterday and am stumped on why the casing around the plug is so small. I can't find an extension cord that will fit it anywhere.. and i've got serious girl spaghetti arms.. it's my preferred choice to start it since i'm in northern ontario and -20 is normal.
Anyone have any suggestions?
kellidotca is offline
post #2 of 27 Old 12-29-2013, 04:10 PM Thread Starter
another angle
post #3 of 27 Old 12-29-2013, 05:18 PM
Thanks (Received): 52
Likes (Given): 266
Likes (Received): 108
Welcome Kelli
I have the same cord receptacle on my machine and encountered the same issue. You'll have to find a cord with an end that will fit, or just buy a cord end and cut off the female end from one your own cords and replace it. You can buy a fancy schmancy Ariens cord if you want as well, but I wouldn't. I'd likely swap out the female cord end. If you go that route, make sure you get the wires on the correct terminals. You'll have 3, green, white and black. Your terminals will be colour coded, green, brass and silver. Green wire on green, white on silver and black on the brass coloured one. You can likely find a YouTube video if you haven't tried this before.
Good luck.
Larry
Larry
Snow Removal Equipment:
2014 Ariens Platinum 24
Blue Hill is offline
post #4 of 27 Old 12-29-2013, 05:20 PM
Likes (Given): 1882
Likes (Received): 663
hello kellidotca, welcome to SBF!! my 826 toro is also a tight fit so i looked around the house for one of these
post #5 of 27 Old 12-29-2013, 05:20 PM
It looks like the problem is the clearance to the right of the ground terminal. I would grind down the plug on your extension cord in that area.
Tom
Tom99 is offline
post #6 of 27 Old 12-29-2013, 05:56 PM Thread Starter
Thanks for the welcome and suggestions it seems strange to me that Ariens would make such a big mistake on a cold weather machine. If the plug doesn't fit a standard extension cord, you're doing it wrong.
Hopefully I'll figure this out before the snow hits again!
post #7 of 27 Old 12-29-2013, 06:00 PM
Likes (Given): 266
It fits a lot of cords, just not the real heavy duty ones. If I was allowed to guess, I would say you might find that identical setup on lots of brands with electric start. Nobody except Honda and Yamaha actually make their own engines.
Larry
post #8 of 27 Old 12-29-2013, 06:13 PM
Thanks (Received): 143
Likes (Received): 297
Welcome to SBF, and as someone else has mentioned, I'd looked at the clearance aisles for Christmas light extension cords, that have a smaller ground nub (little rubber protuberance on the plugs exterior) and either take some nippers, or if you have a bench grinder, slowly work the ground side down until it fits.
I am surprised that this was designed the way it was. It almost looks like it should be oriented 180 degrees from the way that it is. My guess is, that they have done this, so that you will have to buy the proprietary "accessory cord." I don't know if that is the case, but it is the only plausible explanation that I can come up with.
Best of luck.
post #9 of 27 Old 12-29-2013, 06:16 PM Thread Starter
The 24" deluxe has more space between the ground terminal and casing than the 28" but HD didn't have another 28" to test on as they were sold out. Oh well.. they seemed just as surprised as i was.
I've only found a couple of other complaints online, so maybe it's just a given.
post #10 of 27 Old 12-29-2013, 07:08 PM
Thanks (Given): 275
Thanks (Received): 330
Likes (Given): 3338
Likes (Received): 679
I thought all new blowers came with the cord if the machine is equipped with electric start.??? I would see if new machines in the box at the store have them and request (demand) one if they do.
