Ariens 10,000 and 924000 series strength between HP models?? - Snowblower Forum : Snow Blower Forums
post #1 of 57 Old 09-29-2016, 02:24 PM Thread Starter
I've been reading a lot on the different models out there and I'm looking at getting a 10,000 series or the 924000 series.
Is there a difference in the rest of the machine (not the engine) between the different HP models in either series. I see that over the span of each series that there are changes, but that seems to be simply updated designs etc. I'm more concerned with any integral changes to strength between the different HP models in these two series. A yes/no is sufficient unless anyone knows specific information.
Thank you for any input or information.
live4soccer7 is offline
post #2 of 57 Old 09-29-2016, 02:54 PM
Jackmels's Avatar
Thanks (Received): 194
Likes (Received): 814
10000 Series Machines with the Locking Differential are Excellent High Quality Machines that do Not have Gearbox Issues. The 24" Machines have a Great "Feel" to them. My Personal Machine is a Repowered 1965 24" with Tall Chute and Impeller Seal. Works Great and Throws it Far. Highly Recommended.
Jackmels is offline
Thanks live4soccer7 thanked for this post
Likes Georgegn liked this post
post #3 of 57 Old 09-29-2016, 03:17 PM Thread Starter
Are there any functional features on the 924000 series that are not available on the 10,000 series?
Do you know about the strength of the machines between the difference HP models though? I do want to find one with a locking diff.
Does the locking/unlocking diff effect the use of any attachments?
post #4 of 57 Old 09-29-2016, 05:25 PM
Likes (Received): 303
The basic difference is the 10,000 series was a direct drive impeller (like mechanical touching of parts) whereas the 924 series used a second belt to drive the auger/impeller. Depending on years some early models could and would have the ability to go on their own without operator presence, so there can be some safety concerns. I don't think anybody familiar with these machines would say a 7hp is less "strong" than a 12hp, mechanically. They can and will accept much higher power plants. The non-differential models are harder to turn and use without a doubt. If there is a common weak link it's likely the weight of the entire blower can cause axle bearing/bushing wear. Personally I think they all have too low of handlebars. That said I run a '79 slightly modified 924 series I wouldn't sell for any price right now and it doesn't have a differential. It's bear to move around and turns like an aging Aunt in a mall parking lot, but straight line it throws snow like crazy.
post #5 of 57 Old 09-29-2016, 05:49 PM Thread Starter
Thank you very much for that information.
Do all the models in the 10,000 series have the same functionality up at the handle bars or were there additional options there as well?
I know some came with headlights and electric start. Any other standout features that wouldn't be on all models?
Does having a differential model change the ability of it to accept "trac-team" attachments?
post #6 of 57 Old 09-29-2016, 06:36 PM
Trac team was year specific. Have you ever seen Moderator Scot's site? He has compiled a great number of Ariens pdf's and info:The Ariens 1960's and 1970's Sno-Thro info site.
post #7 of 57 Old 09-30-2016, 02:42 AM Thread Starter
Yes, I've read nearly every word on his site regarding the ariens snowblowers.
I'm curious if the locking diff option effects the use of the attachments at all?
I know some came with headlights, diff option, and electric start. Any other standout features that wouldn't be on all models in the 10,000 series?
post #8 of 57 Old 10-02-2016, 10:07 PM Thread Starter
bump.
Anyone know anything on these Qs:
post #9 of 57 Old 10-05-2016, 01:47 AM
Thanks (Given): 16
Likes (Received): 11
Originally Posted by live4soccer7 View Post
bump.
The locking differential has no effect on the use of attachments. The differential axle and locked axle are direct swaps on the standard tractor and have no effect on the two mounting points for the blower housing/attachments. I would imagine the attachments only work on 10,000 series machines due to the change from direct drive to belt drive when the 924000 rolled around.
Headlights are hard to come by with the older machines. I believe they were mostly an option on some of the rarer 32" models. You'd have to see a bigger tecumseh with an alternator for that.
My machine:
Stang is offline
post #10 of 57 Old 10-05-2016, 06:55 AM
Thanks (Given): 11
Thanks (Received): 111
Likes (Given): 19
Likes (Received): 311
One thing I'm surprised hasn't been mentioned on the 924 series is it has a much safer wheel-drive-control scheme.
If you're familiar with the term "deadman control", that's what the 924 and later machines have... if you let go of the wheel "clutch" lever, the machine stops.
The 10,000 and earlier series are exactly the opposite. You squeeze the lever to stop the machine, and when you let go it moves. Which is fine 99% of the time but if you slip and fall on a patch of ice or have a heart attack or something and let go of the handle, the machine will take off and start consuming everything in its path.
The newer machines are also safer in that the auger drive works the same way... you squeeze a handle to engage it, and when you let go it disengages. On the older ones there's a lever down by the chute for that function, and once you put it in the engaged position it stays there.
As others have said, some of the things you mentioned like headlights and lockable diff are options, and were available on both series. The same applies to electric start, but that's more a feature of the engine so if the engine has been replaced, the presence of a starter may not match what's expected for the model.
ELaw is online now
Likes JD in NJ liked this post
