What type of crankcase oil? - Snowblower Forum : Snow Blower Forums
post #1 of 16 Old 10-21-2016, 01:12 PM Thread Starter
Blackstar's Avatar
Likes (Received): 18
I've been looking through threads and tried the search function but I can't seem to find anything about Pros and Cons of Synthetic / Dino oil. This type of open question has been gone over on a regular basis on a couple Harley forums I visit but I haven't seen it here.
I have a 2 year old Platinum 30 SHO with the 414cc engine. I thought read in my manual that synthetic oil wasn't recommended and to use regular dino oil. Is there a benefit to using synthetic in a snow blower? I figure it would be better because of the easier flowing on cold starts.
Appreciate any advice...
Glenn
Ariens Platinum 30 SHO- AX414, 20.0 lb.ft torque.
Blackstar is offline
post #2 of 16 Old 10-21-2016, 01:20 PM
Likes (Received): 1383
If you change the oil every year and use the right weight oil. then NO it does not make a difference for anything.
post #3 of 16 Old 10-21-2016, 02:45 PM
Thanks (Received): 87
Likes (Given): 57
Likes (Received): 269
5W30 Syn and don't think anything more about it. Even the manual recommends 5W30 Syn. How can you go wrong?
GoBlowSnow is offline
post #4 of 16 Old 10-22-2016, 12:51 AM
Thanks (Given): 67
Thanks (Received): 60
Likes (Given): 115
Likes (Received): 81
Glenn
You answered your own question on why it may be better.
Current machines
Ariens 926LE
Toro-8-2-4 is offline
post #5 of 16 Old 10-22-2016, 02:47 PM Thread Starter
Blackstar's Avatar
I figured as much but wasn't sure. The wording in my manual was vague. "5W-30 oil is recommended for general use (synthetic oil is an acceptable alternative). " I think Syn would be better. Thank you
post #6 of 16 Old 10-22-2016, 02:48 PM Thread Starter
Blackstar's Avatar
I've changed it both years I've owned it. This year I was curious whether or not synthetic was better. We get pretty cold winters up here in Nova Scotia. Thanks for the reply.
Glenn
post #7 of 16 Old 10-22-2016, 02:50 PM Thread Starter
Blackstar's Avatar
Yup... Just checking on what others have had good luck with,... Thanks..
Glenn
post #8 of 16 Old 10-22-2016, 03:09 PM
I have ran 10w30 non syn up here in the frozen tundra. AND NEVER EVER HAD A PROBLEM WITH IT.
post #9 of 16 Old 10-22-2016, 03:15 PM Thread Starter
Blackstar's Avatar
I haven't had any problems here either. Just wondering about the best oil for long life. We get extreme cold weather here in Jan-Feb. Sometimes below -20C. Want to make sure I'm making the right choice of lube. Thanks again
post #10 of 16 Old 10-22-2016, 04:19 PM
As long as it is a good brand and you change it every year. then you will be fine does not matter if it is syn or DYNO oil.
