824 with extra's - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 10-26-2016, 07:22 AM Thread Starter
824 with extra's
Just an update so far
mounted new wheel axle bearings (a bit stonger then the original Ariens bearings)
New exhaust
Impeller kit with ratchet lashing band instead of rubber
longer shute
new V belts
stronger skits
ID:	91042   Click image for larger version
ID:	91050   Click image for larger version
ID:	91058   Click image for larger version
ID:	91066   Click image for larger version
Stebekk is offline
post #2 of 5 Old 11-05-2016, 08:48 PM
Thanks (Given): 16
Likes (Received): 11
Solid upgrades.
Regarding the impeller mod: I've been trying to figure out if anything bad happens when you cover up the groove in the middle of the fan blade. Do you have any concerns with salty slush accumulating there and causing corrosion?
How many blades did you do the mod to? 2 or 4?
My machine:
Stang is offline
post #3 of 5 Old 11-06-2016, 02:47 PM Thread Starter
If you're worried for rust maybe you can paint the impeller first. (I did)
I did the mod on al 4 blades, It workt great but I have to think of something else because the ratchet lashing band didn't hold as long as i hoped for
Maybe I will use reinforced rubber.
Stebekk is offline
post #4 of 5 Old 11-06-2016, 04:08 PM
Thanks (Given): 276
Thanks (Received): 330
Likes (Given): 3363
Likes (Received): 683
Some people on the forum use conveyor belting purchased at a farm equipment store. You could also use the sidewalls of an old tire to make new pads since they are reinforced\corded rubber.
post #5 of 5 Old 11-06-2016, 04:42 PM
Thanks (Given): 16
Baler belt from Tractor supply company. I just cut a strip today and am confident that it'll be up to the task.
My machine:
Stang is offline
