ethanol free gasoline - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 10-30-2016, 06:36 PM Thread Starter
for those of you want to use ethanol free gasoline in their snowblowers, and live in or near New York state, many of the Stewarts stores have 91 octane ethanol free gasoline for sale. i purchased 5 gallons this weekend for my snowblower. i think duchess county and greene county (?) have rules against it so the Stewarts there apparently do not carry it.
garthman is offline
post #2 of 13 Old 10-30-2016, 08:27 PM
Thanks (Received): 38
Likes (Received): 63
Available all over the US and Canada: Ethanol-free gas stations in the U.S. and Canada
stromr is offline
post #3 of 13 Old 10-30-2016, 08:43 PM
Likes (Received): 25
I'm new to all this, but wouldn't it be the same to just use stabilizer in your gas? I don't think I'm gonna wanna drive around to just find proper gas for my blower
Toro 824QXE SNOWMASTER
pearlfinish is offline
post #4 of 13 Old 10-30-2016, 11:44 PM
I'm no expert but from my understanding there are a few issues with ethanol added gas, mainly:
- Decreased shelf life of gas,
- Ethanol eats away at plastic and rubber components, I think this is why most stay away, especially in older engines.
- Ethanol is an alcohol and can absorb water from the atmosphere and condensation inside the gas tank. As it ages, the ethanol can come out of solution and settle to the bottom of the tank, along with any absorbed water. This mixture then gets pulled into the carb and you either have issues starting or staying running. Over time the water trapped in the fuel system can corrode the metallic engine components.
I think fuel stabilizer should help with shelf life and preventing moisture from mixing in, but probably does little to protect any rubber and plastic components of the engine.
Shell and Canadian Tire are my go-to in Canada, but I can't seem to find anyone with a dedicated pump. Unless you know the previous customer bought premium, I recommend filling your car for a few seconds to clear the line of unwanted ethanol gas..
cancon is offline
post #5 of 13 Old 10-31-2016, 10:41 AM
Thanks (Received): 98
Likes (Received): 260
I use a product either made by or name Starbrite Gas Treatment which you add to gasoline which, somehow, eliminates the ethanol bad properties and also stabilizes. It winds up costing about $0.10 to treat a gallon, and I have been using it for about 5years with zero complaints, and infinite smiles.
RIT333 is online now
post #6 of 13 Old 10-31-2016, 07:31 PM
I just filled my cherry can today with 91 octane from Shell, and also picked up some stabilizer....all good for the winter
post #7 of 13 Old 10-31-2016, 11:15 PM
Thanks (Given): 51
Thanks (Received): 36
You're talking about Startron and yes it's one of the better stabilizers (according to published tests) but it does not eliminate ethanol's "bad properties". It only helps reduce the instability.
SnowG is offline
post #8 of 13 Old 10-31-2016, 11:19 PM
Thanks (Given): 51
I thought the bowing smilies were praying. I would cycle that stuff through every few months.
SnowG is offline
post #9 of 13 Old 11-01-2016, 08:31 PM
Thanks (Received): 127
Likes (Given): 79
Likes (Received): 172
I have used Star Tron for about 5 years now and it has worked very well. In our area ethanol is used In pump fuel. I add Star Tron as soon as I fill up my gas cans, give it a good shake and seem to be good to go for several months without issue. I have also heard good things about Marine Sta-Bil.
Star Tron Enzyme Fuel Treatment Gas Additive Small Engine
Cardo111 is offline
post #10 of 13 Old 11-01-2016, 08:35 PM
Thanks (Received): 17
Likes (Received): 62
Cancon,
Post your location in your profile and we can help better. Here's a list of locations for the US and Canada for non-ethanol fuel:
CO Snow is offline
